Miks15
| posted on 31/3/10 at 10:04 AM |
EDIS wiring please
Hi all,
I ordered a trigger wheel today. So hopefully will get the chance to fire up it soon. BUt first i need to wire up the EDIS unit.
Has someone got a wiring diagram for it? As simple as possible so i dont get confuzzled
Thanks Guys
big_wasa
| posted on 31/3/10 at 10:15 AM |
Just to show the vr .
If you get it the wrong way around it wont start.
big_wasa
| posted on 31/3/10 at 10:21 AM |
4 6 and 8
Miks15
| posted on 31/3/10 at 10:36 AM |
Cheers wasa.
How does that cable shield thing work?
Also im not going to be running megajolt straight away, just going to run on the limp home mode to get it running so should i just ingnore pin 1 and
3?
Miks15
| posted on 31/3/10 at 10:37 AM |
o and why arent 2 4 and 11 being used?
cd.thomson
| posted on 31/3/10 at 10:41 AM |
Yep ignore the pip and saw to get it running in limp home mode.
2,4 and 11 just aren't used at all. Mine works fine without them anyway
Craig
blakep82
| posted on 31/3/10 at 10:56 AM |
for the shield you need to use something like microphone cable, where you get 2 cables inside, and a braided shield round the outside
its a big photo i borrowed of the internet, so i'll just put the link up.
like this
http://img.alibaba.com/photo/206787672/Microphone_cable.jpg
________________________
blakep82
| posted on 31/3/10 at 10:58 AM |
the edis plug is the same one used for the 4, 6, and 8 cylinder systems. you'll notice from the other 2 diagrams, things move around a little. i
think 2 is something to do with a tacho.
don't worry about pip and saw yet, like craig says. these are for the megajolt, but just get running on the basic set up first
Miks15
| posted on 31/3/10 at 11:24 AM |
ahh ok i see, will the VR sensor need the shield just to get it running? or will i be fine without it too start with?
I assume the connector i have with about 150mm of cable cut off from the original will be shielded?
rayward
| posted on 31/3/10 at 11:31 AM |
Its also worth noteing that on the screened/shielded cable you should only connect the screen to grounnd at one end only, not both ends
hth
Ray
blakep82
| posted on 31/3/10 at 11:40 AM |
i got mine running without shielded cable, so will be just fine.
the shield keeps interfernce out, so if you tried running like that all the time it might be a bit rough. but fine for firing up
big_wasa
| posted on 31/3/10 at 01:38 PM |
The more you do now the less you will have to upgrade later.
wire it as though its done and run the pip and saw to where you will mount the Mjl and tape the end up to stop it touching anything.
If you just lash it up you could short the edis out,
Miks15
| posted on 31/3/10 at 01:56 PM |
hth
Ray
How do you mean? At one end of the shielding? So theres only one connection to the earth?
blakep82
| posted on 31/3/10 at 02:59 PM |
hth
Ray
yes. if you earth at both ends of the cable it can cause a lot of interference, so only earth at one end. and preferable the same point for both
pip/saw and crank sensor cables
