Author: Subject: And now for something completely different
jlparsons
posted on 2/4/10 at 10:26 PM Reply With Quote
Am I ok to use a brass wire wheel arbor on a power drill to remove paint from the stonework on my house? Or will it eat the stone away too much?
Sorry for total lack of relevance, but I figure someone on here is bound to know! I'm not keen on the mess of sandblasting or the toxicity of nitromours so looking at my options.
Ta much in advance!
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television. Keep cool; process promptly.
gazza285
posted on 2/4/10 at 10:30 PM Reply With Quote
Yes, but you will be an old man before it is finished. Try a steel wire wheel in a grinder, preferably a 9" one, then when you are fed up with that, ring a sandblasting company.
Liam
posted on 2/4/10 at 10:49 PM Reply With Quote
Pressure washer? Or too well stuck for that?
iank
posted on 2/4/10 at 11:44 PM Reply With Quote
How much are you looking to get rid of?
You'll wish you'd got it sandblasted if it's a whole house.
Anonymous
MikeCapon
posted on 3/4/10 at 06:56 AM Reply With Quote
I'd use a chemical paint stripper like Nitromors if it's just paint. Sandblasting is a bit OTT just to remove paint. You'll spend longer cleaning up than you think too.
I've just had (most of) my house sandblasted. Here's the front door. The stonework was hidden behind about 20mm of rendering which the blaster had off in about 15 mins. Don't underestimate the work necessary to clean up and finish the edges too...
Door
Door
jlparsons
posted on 3/4/10 at 10:20 AM Reply With Quote
Thanks folks, all replies much appreciated!
It's the window surrounds and lintels on the front of an 1890s terrace house, so a fair bit of surface but not too daunting. Quite right a pressure washer will get rid of a lot of it, particularly on the ground floor where it's pealing off anyway. After that, it's either nitromors, wire wheel or sandblaster.
So, nobody thinks I'm going to get rid of too much stone with a wire wheel?
Anyone played with the sand blasting attachments for common and garden pressure washers? They any good?
ChrisW
posted on 3/4/10 at 11:21 AM Reply With Quote
I've heard of a technique that uses ice instead of sand for blasting. No idea if it's true, or usable in this application, but the advantage we were given is that there's no mess to clean up afterwards.
If you're worried about the sand, might be worth investigating?
Chris
posted on 3/4/10 at 12:54 PM Reply With Quote
I've used a steel wire cup brush to fetch limewash off brickwork but it was only a couple of yards, I wouldn't want to do much more. It cleans the brick up and doesn't do any damage but I needed to point up after.
jlparsons
posted on 3/4/10 at 03:22 PM Reply With Quote
I like the ice idea, though it sounds pretty specialist. Perhaps an unholy marriage of a pressure washer and a slushy machine?
I think after reading the above I'll pressure wash as much as I can off, then try nitromors and wire wheeling it and see what's most effective/less messy.
Thanks again folks!
jlparsons
posted on 3/4/10 at 03:26 PM Reply With Quote
i looked up the ice blaster idea - uses dry ice! Apparently it's much less damaging than sand and it sublimates on impact, penetrating the paint/dirt and expanding into gas underneath it. Looks expensive though!
http://www.youtube.com/watch?v=RA7n-Q4T8hc&NR=1
