richwill
posted on 4/4/10 at 08:47 PM |
fan wiring through thermo switch
i have tried wiring my fan through the thermo switch but could not get it to work. It works ok when wired through a toggle switch though. at what
temperature should the thermo switch cut in and do i wire the live feed to it and from there on to the fan.
adithorp
posted on 4/4/10 at 09:19 PM |
Usually goes...
fused+ to switch
switch to fan
fan to earth.
Switch should have 2 numbers on it for temp it comes on and off, ie. 100/95 would be on at 100'c, off at 95'c.
adrian
http://jpsc.org.uk/forum/
RazMan
posted on 4/4/10 at 10:21 PM |
Careful with the load on the thermo switch - use a relay if in doubt or it will just go pop.
Raz
cosmick
posted on 5/4/10 at 06:28 AM |
If you are using a Yamaha radiator fan switch, then the temp it switches on at should be 105 +-1Deg C and switch off at 99 Deg C. If you want to test
it, place it in some oil and rause the temp on a cooker. Don't use water as it will boil at 100 deg C and it will never switch on. When it is
working inside the radiator, the boiling point of water is around 125 deg C if you use a 1 bar cap.
If it can't be fixed with a hammer then its probably an electrical problem.
