Author: Subject: anyone built a pinto turbo??
luke_stephenson
posted on 11/4/10 at 09:46 PM Reply With Quote
i have a 2.0 litre pinto to go in my kit car. currently has the standard fuel injection system on and is still in car. i also have a set of bike carbs. whats the easiest way anyone has tubro'd this engine?
what were the results, boost? power? intercooling?
finally what internal mods were required?
cheers
daniel mason
posted on 11/4/10 at 09:52 PM Reply With Quote
someone did a robin ood with pinto turbo. it was featured in one of the kit car mags!
dazzx10r
posted on 11/4/10 at 09:53 PM Reply With Quote
I think cosworth did in the mid 80's
prawnabie
posted on 11/4/10 at 09:54 PM Reply With Quote
Carpmat has one in his fury
iank
posted on 11/4/10 at 09:56 PM Reply With Quote
The Transit came with a low compression pinto, that's probably the best starting point for a turbo.
Can make around 185bhp.
http://www.locostbuilders.co.uk/viewthread.php?tid=121061
[Edited on 11/4/10 by iank]
Anonymous
luke_stephenson
posted on 11/4/10 at 09:57 PM Reply With Quote
cosworth YB engine? sounds too expensive, im on about a more heath robinson approach that magicaly gets me 200bhp
daniel mason
posted on 11/4/10 at 10:04 PM Reply With Quote
nissan 200sx are about 200 bhp with no mods, front engined rear drive and cheap as chips!
luke_stephenson
posted on 11/4/10 at 10:05 PM Reply With Quote
already got my sierra im afraid
Rob Allison
posted on 11/4/10 at 11:42 PM Reply With Quote
Done a few pinto turbos. They work well with the standard EFi up to 10psi. I use 7psi on a standard Cosworth 2wd T3 turbo. That gives over 185bhp.
This is my RS2000, the first one i did to see what it would do.
I use a simple log type manifold in stainless steel
Dyno print out with low boost and revs kept down, didn't know if it had enoigh fuel to run right. But all was well.
carpmart
posted on 12/4/10 at 02:28 AM Reply With Quote
I've got one I built in my car.
Send me a u2u with your number and I'm happy to give you a call so we can chat!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
Dale
posted on 12/4/10 at 06:28 AM Reply With Quote
I am using the 2.3 ford factory turbo built in lima ohio in the states. I dont know exactly how similar the engines are but from the outside they sure look the same. Some parts may be interchangeable. They came in the german make xr4ti as well as the north american turbo thunderbird and svo mustangs. Intakes and exhaust maybe direct bolt on. Mine should be somewhere in the 250 hp range. but will hold easily another 100hp all day long.
Dale
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
steve m
posted on 12/4/10 at 08:22 AM Reply With Quote
I also had a 2.3 turbo, in a ford merkur xr4ti
I still have the original ford workshop manuels if any one is intrested ??
boggle
posted on 12/4/10 at 08:55 AM Reply With Quote
must be a popular conversion as i have sold a fair few decomp plates.....
u2u me for details
sucksqueezebangblow
posted on 12/4/10 at 09:03 AM Reply With Quote
I think Practical Performance Car are running a series right now on how to supercharge a pinto. It should have lots of useful tips on pinto forced induction!
Rob Allison
posted on 12/4/10 at 12:32 PM Reply With Quote
2.3 engine is different to the 2.0. No parts are interchangeable.
carpmart
posted on 12/4/10 at 01:09 PM Reply With Quote
I've suddenly clicked with Rob!
Are you RobRS on Turbosport?
'94 MX5 MK1, 1.8
Rob Allison
posted on 12/4/10 at 10:13 PM Reply With Quote
Yes for my sins. Been playing with turbo'ed none turbo engines for some years now.
One limit of the turbo pinto is the pistons/rods. Fit some cossie items and oil pump then it wind the boost up and run up to 300bhp of fun.
There not a bolt it fit though as the pinto crank need to be ground to the cossie big end size first.
