New Topic New Reply
Author: Subject: geometry setup
Arjan356
posted on 12/4/10 at 07:56 AM Reply With Quote
geometry setup
Hello,
Does anybody know the best geometry setup for a indy-ZX12?
Thanks,
Arjan
eccsmk
posted on 12/4/10 at 09:16 AM Reply With Quote
i'd try running the front wheels with zero toe
and 2 deg negative camber
and 1.5 deg negative camber at rear too
this was how i set mine origionaly and it seemed to work well
HTH
Frosty
posted on 12/4/10 at 09:43 AM Reply With Quote
Unfortunately there is no such thing as the best setup. There are so many varying factors which will make different setups work for different cars even if they are the same model.
What's your main use out of the vehicle?
mad-butcher
posted on 13/4/10 at 04:31 PM Reply With Quote
I run 3mm toe in and 2 deg negative camber
also more ground clearance at the rear otherwise she lifts at speed
also in agreement with frosty's comments
tony
jack_t
posted on 13/4/10 at 04:56 PM Reply With Quote
mk recommend 1 degree of negative camber
and track parallel
New Topic New Reply
