Rosco
| posted on 13/4/10 at 11:58 AM |
Fuel Tank Vent.
How do you meet the IVA requirement for a fuel tank vent, below? I've got a non-return valve to cover a dropping level but this will not do
anything for vapour pressure build up on a hot day.
Do I need to worry about vapour pressure? Any IVA friendly solutions?
IVA requirement; "The fuel tank must be fitted with a vent (to permit release of a pressure build up) which does not exit on to the exhaust or
into the vehicle or be situated at such a height that fuel would be likely to leak when the vehicle is driven."
iank
| posted on 13/4/10 at 12:07 PM |
Some fuel caps are vented or have a vent pipe in the body of the unit. The easiest solution is to use one of those.
Anonymous
eznfrank
| posted on 13/4/10 at 12:10 PM |
I've done mine in a piece of fuel hose looped upwards and then back down to just below the level of the floor
wicket
| posted on 13/4/10 at 12:35 PM |
^^ same here, passed SVA OK
JimSpencer
| posted on 13/4/10 at 12:43 PM |
Hi
Short piece of hose and one way vent valve off a MotoX bike.
Bluemoon
Used a vented fuel cap...
