luke
posted on 13/4/10 at 08:58 PM |
front wishbone allignment
just been mounting the front wishbone brackets, created a jig and using the wishbones to possition the brackets.
just as a trial i fitted a hub to double check. I would of thought the two wishbones would be parallel, however when i lift the upright so the bottom
wishbone is level the top one is pointing towards the sky by about 20 degrees. Is this right?
Luke
blakep82
posted on 13/4/10 at 09:00 PM |
sounds about right. keeps the camber in check
________________________
Paul TigerB6
posted on 13/4/10 at 09:15 PM |
Yes thats right. The top wishbone will also be shorter in order to keep the camber controlled.
Cycle it through up and down and you'll see how the camber changes. Lower the bottom arm below the horizontal and the bottom of the upright
starts to pull in whilst the top is still being pushed out, reducing the negative camber. This keeps the inside wheel upright during cornering with it
being progressively unloaded.
luke
posted on 13/4/10 at 09:26 PM |
excellent, cheers guys!
speedyxjs
posted on 14/4/10 at 07:43 AM |
Thats how i have done mine. Give you increased camber when the car leans in the corners.
