New Topic New Reply
Author: Subject: rivet issue
beaver34
posted on 15/4/10 at 07:45 PM Reply With Quote
rivet issue
hi, had my car chassis repowdercated and im trying to figuire out what or how to go around where the old rivets used to be i need to put new ones in what the best way to get the bits of the old ones out?
here is a pic of what is left
beaver34
posted on 15/4/10 at 07:46 PM Reply With Quote
sorry for crap pic
MakeEverything
posted on 15/4/10 at 08:00 PM Reply With Quote
Rivets or Rivnuts?
Kindest Regards,
Richard.
kb58
posted on 15/4/10 at 08:38 PM Reply With Quote
If they're rivets, drill them out. If that doesn't work (they spin), there are specialized bits that hold the rivet from spinning while it's drilled.
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
daviep
posted on 15/4/10 at 08:52 PM Reply With Quote
I think I would probably have removed them before it was powder coated if possible.
As mentioned drill them out, you will lose part of the rivet into the box section.
Davie
russbost
posted on 15/4/10 at 09:02 PM Reply With Quote
As they are now powdercoated why not just leave them in?
beaver34
posted on 15/4/10 at 09:12 PM Reply With Quote
well i could i suppose
Canada EH!
posted on 15/4/10 at 10:09 PM Reply With Quote
Use the same size drill as the rivet, drill them out, the only problem is the back half will fall in the chassis and rattle around, take it slow so the rivet doesn't spin.
If that wasn't new powder coat you could use the ugly grinder then a small punch to knock them back into the chassis.
posted on 15/4/10 at 10:57 PM Reply With Quote
If you can hear a rivet end rattling in the chassis you are not going fast enough . You'd have to pick the chassis up and shake it with your ear next to it to hear anything like a rattle.
New Topic New Reply
