Author: Subject: IVA - Do side lights have to extinguish when main or dipped beam on?
eznfrank
posted on 28/4/10 at 06:18 PM Reply With Quote
I can't find anything in the manual to confirm this but do the sidelights have to go off when the dipped or main beam is on? The reason I ask is because currently my rear lights only come on with sides but if these don't need to go off I should be ok?
In fact, just thinking about it I'm not sure what is normal on the tintop?
[Edited on 28/4/10 by eznfrank]
posted on 28/4/10 at 06:39 PM Reply With Quote
Side lights should stay on with the head lights -- both dip and main beam.
phil m
posted on 28/4/10 at 06:40 PM Reply With Quote
The sides front sides stay on.
They rears are switched to come on when the sides turn on and shouln't be wired to the main and dip
(Think this is correct)
phil m
a simultaneous response
eznfrank
posted on 28/4/10 at 06:53 PM Reply With Quote
Cheers fellas, just been out to check the tintop and it's as per the above, phew - that makes life soooo much easier!!
Danozeman
posted on 28/4/10 at 07:22 PM Reply With Quote
Side lights are on a different circuit so they should stay on.
Dan
posted on 29/4/10 at 08:19 AM Reply With Quote
The power for the headlights is through the sides so you can't have the headlights on without the sides usually.
