Author: Subject: Type 9 clutch arm confusion - please help!
adrianreeve
posted on 29/4/10 at 06:00 PM Reply With Quote
Is there a difference between clutch release arms for 4 and 6 cylinder type 9 gearboxes? I have a V6 gearbox with a caterham spacer and a 4 cylinder bellhousing. I'm assuming that the V6 arm is different to take account of the longer input shaft? Now I've used the spacer, the input shaft is effectively the same length as a standard 4 cylinder one, so I think I need a 4 cylinder arm? If so, does anyone have one laying about that they can sell me?
Cheers Adrian
prawnabie
posted on 29/4/10 at 06:02 PM Reply With Quote
There are at least 4 different arms for the type 9, the length, angle etc are all different. Luckily i found one with "sierra" writted on it from someone on here!
snapper
posted on 29/4/10 at 06:37 PM Reply With Quote
I have done the mod you are doing and yes the v6 arm is longer and won't fit the standard bellhousing, the standard arm is at a more shallow angle usually requiring the Capri release bearing carrier which is 8mm thicker.
I complicated it further by using an RS2000 bellhousing which needed the thinner Rs2000 release arm
I eat to survive
I drink to forget
gavin174
posted on 29/4/10 at 06:45 PM Reply With Quote
this is a pic shamelessy stolen from snapper.. Rescued attachment clutchfork1.jpg
gavin174
posted on 29/4/10 at 06:48 PM Reply With Quote
and another...
snapper has done an article on fitting the V6 gearbox for the Robin Hood magazine...
contact him and im sure he will send it too you.. Rescued attachment clutchfork2.jpg
adrianreeve
posted on 29/4/10 at 07:07 PM Reply With Quote
Typical - mine looks like none of those!
Does anyone have a parts list?
Part number on mine is 90BB-7541_AA
Also has D1E4A
Any ideas
gavin174
posted on 29/4/10 at 07:25 PM Reply With Quote
Have you tried googling the part no
Sometimes works...
