Author: Subject: does someone use R888 SG front and GGG rear?
antonio
posted on 29/4/10 at 08:45 PM Reply With Quote
hi
i used a couple of R888 SG on my track car, but since i have fitted the LSD, rear don't last long (use to do 5-6 track days per set, now 3-4)
i wonder if using SG front ang GGG or even GG rear would make sense.willing to lose a few seconds of course, but want to keep the car well balanced.
merci
PAUL FISHER
posted on 29/4/10 at 10:02 PM Reply With Quote
I don't think the SG are suitable for a rear drive axle for track days if its dry,but would be ok on a damp or wet track,I ran the standard 2G's on the rear of my last Indy R,and the 3g's on the front axle with good results,it help to reduce the understeer I had,with fitting the softer 3G's on the front.
antonio
posted on 30/4/10 at 01:41 PM Reply With Quote
merci paul
i'll try this way, but sg front because ggg out of stock.
cheers
