clairetoo
| posted on 30/4/10 at 03:07 PM |
Wanted - Sierra indicator/hazzard switch
Does anyone have a sierra indicator switch hanging around - the one with the hazard button on top ?
Beer tokens waiting !
Its cuz I is blond , innit
Claire xx
Will weld for food......
Mr G
| posted on 30/4/10 at 03:39 PM |
Remember there are 2 different types of indicator stalk depending on how your full beam/flash is wired. pin 15 indicates a mk1 stalk. You've
also got 'with or without horn push' at the end on the mK1 setup.
G
| posted on 30/4/10 at 06:47 PM |
Do you have a part number , should be on the switch?
clairetoo
| posted on 30/4/10 at 09:47 PM |
I'll have a look in the morning - it's a long time since I fitted it , and I cant remember what type it is
Claire xx
| posted on 1/5/10 at 06:43 AM |
There may be 2 types of hazard switch warning light lens , round or square?
clairetoo
| posted on 1/5/10 at 06:56 AM |
The one on the car is missing the button , so if the cowl fit's either then I'm not fussy !
Claire xx
| posted on 1/5/10 at 07:46 AM |
Not sure if the cowl will be interchangeable or if indeed the switches are for that matter without having to rewire them . If you can get the part
number off the switch it will help . Lolocost or whoever they are now usually have a load in a bucket at Stoneleigh.
clairetoo
| posted on 1/5/10 at 08:06 AM |
There are two numbers on the switch -
30924
85BG13B302 9119 01 G48 190
Any help ?
edit - and there is `pin 15' ?
[Edited on 1/5/10 by clairetoo]
Claire xx
Mr G
| posted on 1/5/10 at 12:01 PM |
As I posted earlier pin 15 means its a mk1 switch, its no good going by the shape of the hazard on the top as they done both shapes on the mk2 but as
a rough rule of thumb square is mk1 and round mk2. Mk1 cowl and mk2 are different.
I had a right old time trying to find a mk1 switch, everyone had mk2 then as rustynuts has mentioned lolocost at a show had a whole plastic container
of them! (with plugs)
[Edited on 1/5/10 by Mr G]
