New Topic New Reply
Author: Subject: Bike engined car
tapkutez
posted on 2/5/10 at 08:03 AM Reply With Quote
Bike engined car
Hello, I have Indy with Fireblade (sc28) engine, and wanted to ask when you change gears is it smooth or you can hear some noises coming from car?
I think its from the differential.
mark chandler
posted on 2/5/10 at 08:24 AM Reply With Quote
They clank and bang loudly unless you match the revs.
When changing up go clutchless, off the gas and pull back, clutch for going down.
If the mixtures are off slightly it will also clank and rattle when cruising, on a bike you have rubber cushioned drives etc, its all a bit harsher when in the car.
A TRT prop will help, I stripped my diff and tightened the mesh on crown wheel to pinion which helped a lot to stop the noise.
Regards Mark
bi22le
posted on 2/5/10 at 08:46 AM Reply With Quote
they do make a racket! My bec use to bang, rattle and make all sorts of clunking noises.
Personally i only clutchless up shifted when driving fast. The box needs to feel a definate release in torque to change with out a clutch. If you do that while driving slowly in town it with just slam the gears together and cause damage.
Please read my ring story:
andylancaster3000
posted on 2/5/10 at 09:55 AM Reply With Quote
Technically speaking for dog boxes (ie bike boxes) there is no real gain to using a clutch, especially on up shifts. It can in fact just cause wear unnecessarily on the clutch and dogs. Useful link here:
http://www.hewland.com/svga/help.htm
[Edited on 2/5/10 by andylancaster3000]
New Topic New Reply
