Author: Subject: Help - whats the tensile stress area of an M42 bolt ?
mcerd1
posted on 15/5/10 at 08:37 AM Reply With Quote
all the books / lists I can find stop at M30 or M36
does anyone know the actual area ?
cheers
-Robert
speedyxjs
posted on 15/5/10 at 08:46 AM Reply With Quote
M42!!! Thats a big bolt!
[Edited on 15-5-10 by speedyxjs]
oliwb
posted on 15/5/10 at 08:49 AM Reply With Quote
Think I am correct in saying it just the area of the diameter of the minor diameter (ie. root diameter). IIRC it would be something like:
pi x (37mm/2)squared
Depends on what type of M42 thread it is and the tolerances etc. What's it for anyhow?
posted on 15/5/10 at 09:06 AM Reply With Quote
1007
see page 299
http://books.google.co.uk/books?id=OIlAtjcZjWEC&pg=PA299&lpg=PA299&dq=m42+bolt+data&source=bl&ots=rC9JRugOxU&sig=FUFMcvGy9ar7t Ko8IqhmTfnvQl4&hl=en&ei=kGPuS7j9M5r60wS9tYnbBw&sa=X&oi=book_result&ct=result&resnum=3&ved=0CCIQ6AEwAjgK#v=onepage&q&am p;f=false
[Edited on 15/5/10 by 02GF74]
posted on 15/5/10 at 09:10 AM Reply With Quote
not far off - the data book states a bit bigger. maybe that takes into account a sliver of the thread?
dunno but google has come up trumps again.
mcerd1
posted on 15/5/10 at 10:39 AM Reply With Quote
thats what I've done for now - and its what the standards tell you to if you haven't got the right info - but my customer will want it more accurate than than
M42*4.5 (its a course thread) -> 34mm dia. -> 907mm^2
but the books I've got (the proper structural data books) have even bigger values than in that data book....
just found this on RoyMech: linky
so I guess I'll need to get the calculator out again
[Edited on 15/5/2010 by mcerd1]
mcerd1
posted on 15/5/10 at 10:51 AM Reply With Quote
Its just the big end of the standard anchor bolts - we use M30 and M36 all the time...
rachaeljf
posted on 15/5/10 at 10:56 AM Reply With Quote
The 1007 mm2 mentioned above is the root area i.e. "Ab".
The tensile stress area of an ISO M42, i.e. "At" is 1120 mm2.
This is the value used in BS 5950 for design of bolted connections.
Cheers R
mcerd1
posted on 15/5/10 at 01:07 PM Reply With Quote
cheers - thats exactly what I was looking for
can I ask were you got that from ?
-Robert
rachaeljf
posted on 15/5/10 at 09:37 PM Reply With Quote
Try BS 3692
Cheers R
mcerd1
posted on 15/5/10 at 09:52 PM Reply With Quote
Try BS 3692
Cheers R
will do - must have looked in nearly every other bolt standard going...
cheers
