Author: Subject: How much to make up one of these (Machinest query)
loggyboy
posted on 22/5/10 at 08:18 AM Reply With Quote
I bought a set of bargain wheels on ebay, issue is one of them has a 4mm larger centre bore so the centre cap doesnt fit.
I need one of these to space it so the cap will clip on.
Any ideas if its a feasable design and who/where/how much? (I guess aluminium would be best?)
Is the section of 1mm profile too slim?
mangogrooveworkshop
posted on 22/5/10 at 08:25 AM Reply With Quote
A lump of ali that diameter is about 6 to 9 quid delivered.
It will take about an half an hour to turn on a myford and here is the bite ......finding someone with the time to do it.
hope that helps
posted on 22/5/10 at 08:34 AM Reply With Quote
Could you build up the centre cap with some aluminium strip to make it fit ? Araldite it as you wind it round till it sets and a bit of wheel silver paint to disguise it.
loggyboy
posted on 22/5/10 at 08:38 AM Reply With Quote
Centre cap is plastic and has 6 'tabs' that clip around the inside of rim with a metal 'c'ring that reinforces them, so not really much to 'build' on to.
Also the larger centrebore not longer has a lip for the tabs to engage with so this recreates that tab. Will also lock them in as the plate is fitted on the inside and the cap secures from the outside ans is wide enougth to lock it in.
[Edited on 22/5/10 by loggyboy]
loggyboy
posted on 22/5/10 at 08:47 AM Reply With Quote
Like this: Rescued attachment WheelHubSpiggot2.gif
balidey
posted on 22/5/10 at 10:21 AM Reply With Quote
May be cheaper / easier to buy a new set of larger centre caps and just use one on that wheel
Dutch bears have terrible skin due to their clogged paws
ashg
posted on 22/5/10 at 11:07 AM Reply With Quote
get a lump of ali and i can do it for you one evening.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
flak monkey
posted on 22/5/10 at 07:22 PM Reply With Quote
I could do it for you. As mentioned though the only downside is price... (i seem to be good at talking people out of giving me jobs!)
If you get stuck, send me a U2U and I'll see what I can do.
Sera
http://www.motosera.com
