Author: Subject: Hayabusa gear box
MydT9
posted on 23/5/10 at 06:26 PM Reply With Quote
Hayabusa gear box
Can anyone tell me where I can get a steel / alloy connector bar that has a splined hole to fit the gearbox shifter output (splined little end) to attach to my gear shifter rod?
On my old honda blackbird i simply cut down the alloy gear pedal which had the splined hole on one end but the Busa seems to be a 2 piece linkage affair and can't seem to locate the splined end version anywhere.
On the Radicals they have 3" narrow steel bar with a splined washer welded to it with holes along its length to alter the gear lever travel - anything like this would be good too...
Thanks,
Mydrian
Myd
http://uk.youtube.com/watch?v=RPWhhbaPG4o
Phil.J
posted on 23/5/10 at 06:42 PM Reply With Quote
Have a look on Ebay for a GSXR gear linkage/ drop arm. I think the spline size is the same across the GSXR range.
I use the drop arm from a GSXR1100 on my 'busa engine.
Browny
Junior Builder
Posts 32
Registered 6/6/07
Member Is Offline
Photo Archive Go!
Building: Space framed Fiat Seicento with zzr1400 engine.
posted on 23/5/10 at 06:54 PM Reply With Quote
Phone Mk Sportscars, they have the splined parts on stock, you simply weld on the relevant lengh arm that you require.
richard thomas
posted on 23/5/10 at 06:55 PM Reply With Quote
I managed to use the original connector...worth a try?
MydT9
posted on 23/5/10 at 08:09 PM Reply With Quote
Many thanks for the swift replies. I don't have the original linkage and as I will be running a Kliktronic actuator with paddles i just need a basic bar and I can make up the rest.
No luck with Ebay and breakers want silly money for an used part which i will be cutting up anyway.
Something will show up.
Myd
Myd
matt_gsxr
posted on 23/5/10 at 10:36 PM Reply With Quote
Suzuki use a 14mm spline across the range. This is different to other japanese manufacturers.
There were some earlier bikes with a simple "rod" (later bikes have the lever further back and use an actuating arm). The air/oil cooled gsxr1100 and the early gsxr400 might be appropriate.
Maybe "GEAR Change LEVER Universal Fit 4 SUZUKI DR GS RM TS"
Matt
MydT9
posted on 23/5/10 at 10:58 PM Reply With Quote
Matt
Matt, you are a STAR !!! ;-)
Thanks,
Myd
Myd
