Author: Subject: engine mounts
fideel109
posted on 24/5/10 at 08:44 PM Reply With Quote
engine mounts
This weekend after a long drive in the sun I've had the feeling that the rubber engine mounts were getting softer, allowing much more engine movement.
After a night sleep, these mounts feel stiffer
Has anyone here on the forum have had the same experience?
I would like to find some stiffer ones for my Avon, any suggestions?
jp
posted on 24/5/10 at 08:50 PM Reply With Quote
Depends, what do they look like?
Land rover ones spring to mind but depends what you have atm.
I'm experimenting with an engine steady bar after finding mine moves around touching the chassis in a couple places... Rescued attachment Engine Steady.jpg
posted on 24/5/10 at 09:00 PM Reply With Quote
That's going to be a bit noisy, a rubber bushed stabiliser might be a better idea?
jacko
posted on 24/5/10 at 09:03 PM Reply With Quote
This is my engine stabilizer
More photos in my archive
Jacko
[img][/img]
Rudy
posted on 29/5/10 at 06:28 AM Reply With Quote
JP, I used regular industrial silent block (not automotive) they just work.
My avon have (sierra) gearbox support not too hard, I can't find an harder one. About front engine supports , ones of mine (left one) breaked (for the vibrations) and i had to reweld it and renforce. So look if you support need some weld ?
Ciao Rudy
Sorry about my English
fideel109
posted on 1/6/10 at 06:35 PM Reply With Quote
Hi Rudy,
You're right about the engine mount, my left one has been reinforced.
It started to bent...
Ciao,
jp
flak monkey
posted on 1/6/10 at 06:48 PM Reply With Quote
Landrover engine mounts and a westy/caterham gearbox mount will stop it moving.
Fiesta engine mounts are waaaay to soft (from experience!)
Sera
http://www.motosera.com
AvonBelgium
posted on 2/6/10 at 08:29 PM Reply With Quote
JP,
I ordered me some Land Rover silent mounts after "the weekend" ;-)
I did not had the change to mount them, but they seem to be very rigid compared to the Fabory ones.I let you know the result ones they are mounted.
You need the Land Rover Defender V8 engine mounts, I found them on ebay.
D= 75 mm
H= 38 mm
M10 studs 25 mm long
Groetjes
Gunther
[Edited on 2/6/10 by AvonBelgium]
