Author: Subject: Tin top strange noise - help please
chris-p-duck
Contributor
Posts 256
Registered 16/4/07
Location West Mids
Member Is Offline
Photo Archive Go!
Building: a sense of satisfaction now things seem to work ok
posted on 26/5/10 at 04:29 PM Reply With Quote
Hi all, I need some advice as my tin top has started making some strange noises. Its an Audi A4 1.9 tdi (non quattro) with 170k miles and when I have any steering lock on at speed (40 mph plus) I can hear a w-w-w-w-w-w-w-w-w-w-w sort of noise from the front drivers side wheel. Occasionally it happens with the wheels straight ahead but it is far more pronounced with some steering angle on. I can feel slight vibration thru the steering wheel and braking makes no difference (apart from slowing the car down!!) It seems to be road speed related.
So any ideas? Hub bearing? CV joint?
Any advice gratefully received
Chris
zilspeed
posted on 26/5/10 at 04:31 PM Reply With Quote
Tyre carcass with a twist on it ?
It really isn't unheard of and would give a rythmic swishing noise.
Agriv8
posted on 26/5/10 at 04:35 PM Reply With Quote
I would suspect a CV Joint regards
Agriv8
norfolkluego
posted on 26/5/10 at 05:11 PM Reply With Quote
Power steering pump?
Nah, just read your question again.
Lost balance weight?
[Edited on 26/5/10 by norfolkluego]
chris-p-duck
Contributor
Posts 256
Registered 16/4/07
Location West Mids
Member Is Offline
Photo Archive Go!
posted on 26/5/10 at 05:23 PM Reply With Quote
would a balance weight only affect it with the steering turned though?
chris
Wheel bearing almost certainly. Steering left or right will load and unload the wheel with the duff bearing so you should be able to work out which side it is.
r1_pete
posted on 26/5/10 at 06:00 PM Reply With Quote
I'd go with the wheel bearing too, had a similar issue on a fwd cavalier many years ago...
Marcus
Wot Mike said, deffo wheel bearing. If you put enough lock on at 40 to hear a driveshaft issue, you'd be in the hedge
Marcus
Because kits are for girls!!
chris-p-duck
Contributor
Posts 256
Registered 16/4/07
Location West Mids
Member Is Offline
Photo Archive Go!
posted on 26/5/10 at 06:14 PM Reply With Quote
is a bearing change something i can do or is it a dealer job? special tool? does it need pressing in or anything?
cheers
chris
Ninehigh
posted on 26/5/10 at 07:48 PM Reply With Quote
If it's the same kind of bearings I've been refitting in college you could do it yourself, but you'd need a press.. About 4 tons of pressure iirc.
Then again that's the rings the bearings sit in, the bearing themselves you could replace but it might well be doing half a job. Like replacing brake pads only when the disc needs changing too.
posted on 26/5/10 at 10:15 PM Reply With Quote
CV joint tends to be a click-click-click noise when turning slowly at full lock. Bearing gives a more thrumming noise as described.
