Paul TigerB6
| posted on 29/5/10 at 04:39 PM |
Painting brake calipers
Evening all
I'm just refurbing some brake calipers before fitting to my car. Do freshly derusted calipers need a primer before applying Halfords brake
enamel??
| posted on 29/5/10 at 04:52 PM |
A very light mist coat of Zinc rich primer then you can any car paint --- calipers really don't get very hot.
Paul TigerB6
| posted on 29/5/10 at 05:49 PM |
Thanks BT - zinc primer it is then.
| posted on 29/5/10 at 06:31 PM |
Which zinc primer please??
dhutch
| posted on 29/5/10 at 07:15 PM |
I would expect most would be suitable assuming there comptabile with the topcoat of choice, you just aiming for a bit of galvanic protection in the
case of damage to the paint.
Im considering this myself, as the price diffrence between a coat of holding paint and powercoated from big red is £40 (£109 power, £85 zinc, £69
holding paint only)
Daniel
David_17
| posted on 31/5/10 at 05:55 PM |
quote: Originally posted by britishtrident
...you can any car paint --- calipers really don't get very hot.
I disagree, but it's up to you.
[Edited on 31/5/10 by David_17]
dhutch
| posted on 2/6/10 at 08:46 PM |
quote: I disagree, but it's up to you.
Well, it depends how you define hot.
If nothing else, dot 4 fluid boils at around 200c, which while not cold, is going to equate to a sub 100c caliper temp in most applications.
Daniel
franky
| posted on 3/6/10 at 06:59 AM |
anything over 14 deg C in the UK is defined as hot
