The Knobs
posted on 7/6/10 at 08:54 PM |
Bolt on arch spacing out from body ?
I have bolt on arches on my Striker and may need to space them out from the body possibly up to 10mm. Question is, what can i fill the gap with
without using mastic ? It is a track car so doesnt have to be a pristine fit, but would some sort of dense foam be suitable ?
big_wasa
| posted on 7/6/10 at 09:00 PM |
Mdf or ply. draw around the arch and cut it out with a jigsaw.
You could cut the arch and glass a band in.
norfolkluego
| posted on 7/6/10 at 09:17 PM |
That's what I did (with MDF, a lot cheaper than 1mm ply). If you use MDF make sure you waterproof it well, I slopped on waxoil then covered in
coloured tape, actually looks a lot better than it sounds
Pic with rear arches extended about 25mm
norfolkluego
| posted on 7/6/10 at 09:19 PM |
Meant cheaper than 10mm ply
Irony
| posted on 7/6/10 at 09:47 PM |
I am sure Woolies will have something
http://www.woolies-trim.co.uk/
norfolkluego
| posted on 7/6/10 at 10:00 PM |
I'm sure they would but I bet B&Q and 15 minutes with a jigsaw is cheaper
The Knobs
| posted on 7/6/10 at 11:05 PM |
mdf and gaffer tape looks the way forward then.
