Author: Subject: p clips for brake lines
AndyW
posted on 10/6/10 at 07:38 PM Reply With Quote
Quick question,
"P" clips for brake lines, can I use the plastic ones or do they have to me the metal ones with rubber coating???
austin man
posted on 10/6/10 at 07:44 PM Reply With Quote
I use the plastic ones without problem for the SVA
franky
posted on 10/6/10 at 08:32 PM Reply With Quote
you can also use cable tie bases and cable ties.
Werner Van Loock
posted on 10/6/10 at 08:43 PM Reply With Quote
i used oversized plastic ones and lined them with a split old fuel line to protect the copper, if you're talking about copper lines though, otherwise plastic ones are fine.
Did same for brake lines.
http://www.clubstylus.be
wilkingj
posted on 10/6/10 at 08:51 PM Reply With Quote
IN used the stanless ones with the rubber shield.
However I have also used cut up cycle innertube as a filler / flexible spacer (not on this build, but on my Land Rover.
Best Regards
Geoff
http://www.v8viento.co.uk
posted on 12/6/10 at 12:29 PM Reply With Quote
Use proper plastic push in brake pipe clips --- P clips don't look professional.
nz_climber
posted on 12/6/10 at 11:07 PM Reply With Quote
I don't understand your comment, nothing un professional about a proper p clip like pictured below, they are 100 times better than any plastic clip! They are used in the aviation industry for all pipes and wiring looms for a reason!!
http://aarons7.wordpress.com
eddie99
posted on 12/6/10 at 11:09 PM Reply With Quote
Yep also want to know whats unprofessional about p clips. And i think you have to have p clips for brake and fuel but can have cable tie bases and cable ties for wiring only. Thats what i was told anyway.
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
