iwbunting
| posted on 21/5/04 at 09:59 PM |
Rear IRS
Heeeeeellp.
I really want to use rear IRS on my mcsorley chassis build.Does anybody have any proven dimensions or ideas that i can use to build the rear end.Ie is
toe out needed,what length of arms etc.I am using sierra shafts and diff.
Cheers.
Ian
pbura
| posted on 22/5/04 at 04:41 AM |
Ian,
I would not hesitate to use these:
http://www.georgecushing.net/SierraIRS.html
There are a few ways to revise them for a +442, but I think the easiest would be to keep the wishbones the same and add 4" to the width of the
diff cage. There would be no change to the height of the diff cage, but you can change dimensions of the bulkhead, rear deck height, etc., to fit the
+442 design.
All IMO, of course. I suggest that you email George C. if any questions.
Pete
Pete
James
| posted on 22/5/04 at 03:56 PM |
Ian,
Have you thought about using Dozracing's DeDion system?
It's lightweight and apparently works well. You would use your Sierra donor parts but you don't need to worry about wishbones etc.
HTH,
James
Jasper
| posted on 22/5/04 at 04:21 PM |
Listen to the man, he's spent the last 2 years trying to get his IRS sorted
(Says the person whose spent the last millenium trying to get his through SVA emissions    )
[Edited on 22/5/04 by Jasper]
Mix
| posted on 23/5/04 at 05:41 PM |
I'm basing my rear IRS, 'loosely' on the dimensions in the Tiger book.
Yes IRS is a bit of a minefield but I, for one, am determined to get there, there is plenty of good info on here so if that's what you want then
go for it. If you want a quick build then it might be prudent to think again.
Mick
phelpsa
| posted on 23/5/04 at 05:50 PM |
Out of all the IRS system my locosts previous owner chose to recreate it had to be ST. This means the shock is mounted on the bottom wishbone which
means it differs a lot from the book. You have to chop out bars and reposition them in different places.
Adam
