| posted on 16/6/10 at 12:43 PM |
Modified Audi RS4 V8 Engine For Sale
Well... I guess it has to go!
SOME INFO
The B7 RS4 engine is one of Audi's Fuel Stratified Injection units (FSI).
STANDARD TRIM ENGINE-SPECS:
4163cc V8 32 Valve
All Aluminium
2 x DOHC
Variable Valve Timing
8250 RPM
12.5:1 CR
414 BHP @ 7800 RPM (flywheel)
430 Nm @ 5500 RPM
The engine was sourced in 2007, and came from a 2006 MY Audi B7 RS4 that had covered 4k miles. My intention was to install it in an Ultima, but poor
health has forced a change of plans.
The brief was to have a lightweight, powerful, high-revving and reliable power-train.
The Audi FSI system is notoriously difficult to control if the engine is removed from the production car due to the incredibly high fuel pressure
required, therefore this particular engine has had the FSI system disabled.
First off, the engine was delivered to a professional engine-builder where it was stripped and ALL components cleaned and inspected. No faults were
found whatsoever – everything was tip-top.
The power-steering and air-con pumps were removed and the internal drive gears were deleted. Their drive-ports were core-plugged.
The twin fuel-pumps were removed and the ports were core-plugged.
The water-pump assembly and drive were removed and the port was core-plugged.
The heads were sent to a specialist engineer and the FSI and Secondary-Air-Injection-ports were weld-sealed. A pair of bespoke aluminium inlet
manifolds were fabricated along with a set of 8 aluminium velocity-stacks. These mate to a twin-set of Keihin throttle bodies with a set of 380cc/min
injectors (max 460 BHP @ 80% duty-cycle).
The inlet manifolds and heads were then ported to match and the engine re-built.
Engine mounted oil-cooler and standard exhaust manifolds are present. I also have the OEM engine-sensors which will no doubt come in handy.
To complete the engine for installation, you will need:
1. To have new engine coolant pipes fabricated - I have sourced a set of damaged ones which will serve as templates, and I can supply the original RS4
water pump so that an inlet for an electric pump set-up can be made.
2. To have twin fuel-rails fabricated.
Any requirements thereafter would be unique to your install needs (wiring, ECU, flywheel, Clutch, electric water pump, plumbing, air-filter, radiator,
ancillary oil-cooler, etc.). None of these are supplied, but I can recommend THESE GUYS as a top-source for
most bits and information. They have worked on Audi V8's and V10's for Ultima installations and know their stuff!
I cannot warrant this engine – it is sold as seen. I would urge any interested parties to come up for the day and have a good look around it whilst
it's still at the engine-shop. This would allow you to have all your questions answered by the builder.
So far, the engine has cost me around £8k
I would accept £5k for a quick sale (no haggling on this one I'm afraid... I think I'm losing enough!). I would also personally deliver it
anywhere in the UK compete with engine stand.
I would also consider any 'interesting' P/X's... cars, bikes, etc.!
ENGINE AT THE WORKSHOP
ANOTHER ANGLE
SHOWING THE AIR-CON AND PS PUMP DRIVE-GEARS WHICH HAVE BEEN REMOVED
DEMONSTRATING THE QUALITY OF THE ALI FABRICATION ON THE INLETS
PORTING
It's Evolution Baby!
cd.thomson
| posted on 16/6/10 at 12:55 PM |
stick it in a gt40 replica and I'll have it
Craig
| posted on 16/6/10 at 12:56 PM |
Noooo... a GT40 replica needs a booming old-school Ford V8!
v8kid
| posted on 16/6/10 at 02:00 PM |
Looks like a bargain for someone I spent considerably more than that on my Rover 5l.
Excellent power and torque for the dosh in this Audi unit.
skinned knuckles
| posted on 16/6/10 at 02:32 PM |
if i had 5K you'd have a sale. that sounds like a nice engine. shame its more than my total budget for the car
A man isn't complete until he's married, then he's finished
| posted on 16/6/10 at 04:11 PM |
Thanks for the comments guys!
imp paul
| posted on 16/6/10 at 05:01 PM |
that's 1 nice motor Scott some 1 will have a lot of fun with that
| posted on 16/6/10 at 05:07 PM |
Cheers Paul... I just wish it was me!
That said - I do have a single-seater in pieces in the garage - wonder if it will go in there!
| posted on 14/10/10 at 08:17 AM |
Reduced to £3999
coyoteboy
| posted on 14/10/10 at 10:28 AM |
Stunning engine. Can't afford that sort of cost (plus I'd like to do the work myself TBH) but I do have a question, if I can? What does it
weigh? From teh figures I've seen this engine should push out some fairly impressive power/weight figures even in standard trim.
| posted on 14/10/10 at 11:43 AM |
Cheers CB... it was briefly built-up with clutch / flywheel and its fully dressed weight was around 190kg.
I would be VERY disappointed if it didn't make 400bhp at the flywheel. The official Audi figures state 416. Obviously I've junked the
FSI system in favour of a traditional TB set-up, but as there's been a bit of headwork done and all the emissions gizmos have been deleted, then
I would hope to recoup most of any power lost.
It's all guesswork... opinion is split as to whether there will be any power loss at all as many think that with the right injectors and good
mapping then it may even top the FSI's figures.
| posted on 14/10/10 at 08:17 PM |
Potentially sold... to someone looking to recreate a Renault Espace F1 thingy
Hope the deal goes through - this is just the sort of home I would like it to go to!
