Author: Subject: BEC low water temps
bassett
posted on 19/6/10 at 12:47 PM Reply With Quote
BEC low water temps
Hi, i was talking to the owner of a rolling road today and he was asking what temp our car runs at and commented that its too low. Our normal driving temps are 72-78 deg going to 100ish in traffic as indicated on the R1 clocks, is this too low on an R1 02-03 FI model with polo rad? if it is what are the implications and should i raise the temp by resticting rad airflow?
Adam
[Edited on 19/6/10 by bassett]
spdpug98
posted on 19/6/10 at 01:37 PM Reply With Quote
Hi Adam
My temps are even lower than that, during mild mornings i'm lucky if it will go into the 50's never mind 60's. (I do have the race 4 core rad)
I have taken to taping up the gaps on my nose with tape, if the temps start getting too high I remove one strip. Even in this weather I have to have at least 2/3 bits of tape on the nose
My Blog: http://spdpug98.wordpress.com/
posted on 19/6/10 at 02:30 PM Reply With Quote
Depends where you are measuring the temperature.
daviep
posted on 19/6/10 at 03:27 PM Reply With Quote
Do you have a thermostat in the system?
ReMan
posted on 19/6/10 at 03:56 PM Reply With Quote
Mine runs cool according to the bike clocks gauge, but I'd rather it that way and I can't see why it should be a problem on carbs, maybe if there's some EFI magic going on?
bassett
posted on 19/6/10 at 04:06 PM Reply With Quote
Yes thermostat is still fitted and the sensor im unsure where but its the original that feeds to ecu/clocks. Chap at the RR said if its not running regular temp, he thought 90 deg c then it wont run 100% effecient etc. Any truth in this or should i leave as is?
afj
posted on 19/6/10 at 06:10 PM Reply With Quote
72-78 is what mine runs at,
when the engines in the bike they run at around the same so its fine imho
[Edited on 19/6/10 by afj]
eerrrrrrrrrrrrrrrr
bassett
posted on 20/6/10 at 09:14 AM Reply With Quote
Great thanks guys il run it as is and make sure ive got a fan on it to keep it at this temp for the RR
Strontium Dog
posted on 20/6/10 at 11:49 AM Reply With Quote
It's more to do with your oil being at it's optimum working temp.
GeorgeM
posted on 21/6/10 at 11:00 AM Reply With Quote
RR should have a mahoosive fan in front of your car keeping it cool. If not I wouldn't let them near mine. Your rad fan will not simulate air speed.
GeorgeM
My conscience is clear - I drive a GREEN car
MNR Racing
essexkitcarclub.com
Frosty
posted on 21/6/10 at 02:45 PM Reply With Quote
For what they cost (a few quid), it might be worth replacing your thermostat. If the thermostat is stuck open a bit, it could well be overcooling the engine.
If other R1 engines indicate higher temps then this is where I would look first. The radiator barely comes into play until the thermostat opens, so I doubt the radiator is over-cooling, or the thermostat would close again.
It could also be worth checking the actual temperature with a IR gun so ensure the sensor is not playing up.
JoaoCaldeira
posted on 24/6/10 at 10:46 AM Reply With Quote
I also have that range of temps just before the original thermostat housing - 2003 R1.
Joao
bassett
posted on 24/6/10 at 09:19 PM Reply With Quote
Cheers for the confirmation Joao, time to see what bhp shes putting out and then see if a little bit extra can be squeezed out
adithorp
posted on 28/6/10 at 04:08 PM Reply With Quote
5VY 'stat opens at 85' and closes at 72'. If the rad' is big enough and the air flow good enough, it should hold between those figures. Mine did even in the south of France last week. It did creep up doing the passes at full chat though.
adrian
http://jpsc.org.uk/forum/
