Author: Subject: VW golf cuts mid driving
Lars
posted on 20/6/10 at 08:28 AM Reply With Quote
My sister has a vw golf r reg 2.0 gti (8valve)
She says while driving it will every now and then just cut out
I have checked the car and can't find anything obvious.
Thought it may be a blocked fuel filter, but that was changed and still did not fix it.
earth leads seem to be in good condition.
Apparantly some of the relays were prone to fail, but she has changed those with no luck.
Anyone know what might cause this?
jossey
posted on 20/6/10 at 10:00 AM Reply With Quote
find out what it does when it cuts out.
does i sputter to a stop or just stall?
maybe worth checking the injectors see if they fill the same amount.
and then see if it maybe a problem with fuel lines.
my fuel pump got blocked after i ran my car dry one day. i had to strip n clean and since then it aint cut out but stilll misses occasionally so im getting the injectors looked at.
dave
posted on 20/6/10 at 02:26 PM Reply With Quote
Crank sensor or connections.
Lars
posted on 21/6/10 at 03:03 PM Reply With Quote
Thanks guys will check.
FYI it is a straight cut i believe no stutter
posted on 21/6/10 at 04:34 PM Reply With Quote
Very common problem on the Mk3 Golf, as BT says the crank sensor would be number 1 suspect.
