Bumble
| posted on 23/6/10 at 09:09 PM |
Denso Alt - Charge Light - Help Please!!!
Ok help please, I have small Denso Alt (3 pin type) on my Zetec. I have ETB Digidash 2 which has no charge warning light. Do I need one??
The wiring diagram in the Westfield site for the Denso Alt has main ring term on Alt connected to 12v term on Starter motor. Second terminal to 12v
Ignition Switched supply and third terminal to Charge Warning light.
What to do?????
Help much appreciated...I'm hoping to fire her up for the 1st time this w/end but I'm unclear on this.
Thanks,
Matt
flak monkey
| posted on 23/6/10 at 09:17 PM |
Basically you have 4 connections
Main battery/charge - connect direct to batt positive or starter motor.
Sense - connect to a switched live, coil feed is ideal
Switched live - connect to any switched live feed
Charge light - connect to charge light
You should be able to identify the connections from this site:
http://www.fae.co.za/Web%20Catalogue%20Pdf/Regulators/Nippondenso%20Regulators.pdf
The pins are the same layout on the round pin connectors IIRC
You may find it charges, but the light doesnt go out - mine does this, but I have left it as I have set another programmable light on my dash.... If
you need your charge light to work then it might need a transistor to switch it.
Sera
http://www.motosera.com
Bumble
| posted on 23/6/10 at 09:38 PM |
Hi Flak.....you've confused me a tad further.....I have 3 pins only as per the top left image on the westie site - see
attached.Westie Link
Batt conection = OK - simple
12v Switched = OK - simple
Charge Lt - Diigidash doen't have one so do I need one or not....unsure.
My premier loom has charge light wire but nothing to connect to at Dash end.
Matt
flak monkey
| posted on 23/6/10 at 09:40 PM |
Ah, sorry mis understood
You will need one otherwise the coil in the alternator may not energise properly and it wont charge.
You just need a light with one side connected to a switched live and the other to the connection on the alternator
Sera
Bumble
| posted on 23/6/10 at 10:02 PM |
I have a spare savage warning light I couold use...would that be OK??
Mr G
| posted on 23/6/10 at 10:27 PM |
You need to use a transistor to get the charge light working.
Linky1
Linky2
[Edited on 23/6/10 by Mr G]
eddie99
| posted on 23/6/10 at 10:45 PM |
Yep any light would be ok! But it does need one!
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
whitestu
| posted on 24/6/10 at 09:03 AM |
Depends on the Denso alternator. On mine the charge light output is just a signal to swich the charge light on. It doesn't do anything else and
the alternator works fine with it uncoupled.
paulf
| posted on 24/6/10 at 09:18 AM |
As it has a 12v switched live feed it most likely does not require the charge light to work.I would just connect it with out and see if it charges.I
had a denso that had a faulty light out put but it still charged fine.
Paul
sssline
| posted on 8/7/10 at 07:30 PM |
Apologies for jumping in on this thread, but can you use a 12v LED as the charge light?
Hammy360
| posted on 31/10/11 at 08:42 PM |
Matt
Hi mate
Im going through exactly this right now, what was the solution?
