phil4521
| posted on 26/6/10 at 11:52 AM |
Labels for IVA
Looks like for IVA I need a label for the brake balance bar and also the brake fluid reservoir...
Can anyone tell me what the exact wording needs to be and what are the rules regarding size, material for label and placement?
big-vee-twin
| posted on 26/6/10 at 11:54 AM |
The wording is in the manual, CBS sell master cylinder sticker.Someone on here has had some bias bar stickers made up
http://www.triangleltd.com
40inches
| posted on 26/6/10 at 01:55 PM |
MNR do them. I think
russbost
| posted on 26/6/10 at 02:01 PM |
CBS want £6 P & P!!!
I can do the brake fluid stickers for £1.99ea posted
blakep82
| posted on 26/6/10 at 08:18 PM |
whats the bias bar label all about?
________________________
stevegough
| posted on 26/6/10 at 09:21 PM |
Some thing along the lines of
"The bias setting is fixed - if you remove the fixing and adjust it you may be in contravention of regulations and leave yourself wide open for
the nearest police constable to book you."
Might be a little off on the wording....
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
40inches
| posted on 26/6/10 at 10:43 PM |
Note 6:
" Adjusting front/rear brake bias may invalidate approval and breach Construction and Use requirements."
raptor700
| posted on 27/6/10 at 09:04 PM |
all my switches are savage ones they have a pic showin whta they are eg, side lgiht and hazards i labeled the reverse as it uses a blank one, i have
now labeled them all as this is whta nhe wanted even tho the pic clearly shows
