cd.thomson
posted on 26/6/10 at 12:46 PM |
c20xe oil pressure release valve
not getting any oil pressure in my engine.
tried taking the oil pressure doodads out - took the cap off, out comes the spring but if the "plunger" type thing is in there then it
isnt coming out..
any possible solutions?
Craig
cd.thomson
posted on 26/6/10 at 02:33 PM |
panic over, got it out..
time to spend some money with SBD
Craig
perksy
posted on 26/6/10 at 04:14 PM |
Unless its badly scored sometimes you can get away with giving the valve a good polish with some very fine wet & dry
Always check the valve housing inside the oil pump body though, becuase *if* thats scored your looking at a new pump
cd.thomson
posted on 26/6/10 at 05:48 PM |
thanks perksy,
it is only lightly marked but I never want this to happen while pushing the engine towards 7000rpm so I'm keen to fit the nylon replacement.
Craig
Ben_Copeland
posted on 26/6/10 at 06:50 PM |
I'm going to be ordering mine soon too... Shame its about £50
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
matty h
posted on 26/6/10 at 09:44 PM |
Anyone got a link to the upgraded relief valve.My 2.0 8v same block as 16v takes a couple of seconds for the oil light to go out would this valve stop
this.
speedystew
posted on 27/6/10 at 10:26 AM |
here's a link it's in the picture with the oil pump
http://www.sbdev.co.uk/Dry_Sump_Systems/Oil_Pump/Oil_Pump.htm
