irvined
posted on 26/6/10 at 08:05 PM |
Crossflow Noise
So, after I spun a bearing due to an oil pump failure a few weeks ago, spent the weekend building up a new engine.
I started it up, and rattle rattle rattle. Sounds like very very loud tappet noise.
Its a 'new' engine, ie, rebored, new bearings etc, assembled by Jem Engines so i'm fairly sure the bottom end is good.
The only other thing that is not tried and tested is the sump, I know 1300 sumps make a racket, I measured the depth of the new one, and it seems to
be the same as the one that came out.
Compression is normal, tappets don't need adjusted, cam timing is ok, I can't feel anything clashing when i turn it over by hand.
What else could it be? I'm totally stumped (And gutted.)
http://irvined.blogspot.com
r1_pete
posted on 26/6/10 at 08:10 PM |
Are you sure you dont have a rocker which is stiff on the shaft and giving a false reading?
Have you checked the cam chain for slopping around?
[Edited on 26/6/10 by r1_pete]
clairetoo
posted on 26/6/10 at 08:13 PM |
1300 sumps are narrower than 1600 sumps - are the rods hitting the sides ?
I once got a nicely modded sump on a 1300 bottom end I picked up , couldnt resist fitting it to my 1700..................sounded like a bag of
spanners on startup
Its cuz I is blond , innit
Claire xx
Will weld for food......
Bigheppy
posted on 26/6/10 at 08:24 PM |
I rebuilt a 1600 and had a similar problem, It turned out to be a little end bearing. Some sh1t had managed to block the oil passage to that piston
and wrecked the bearing.
locoR1
posted on 26/6/10 at 08:33 PM |
As claire said if its a 1300cc sump on a 1600cc rattle rattle rattle Guess how i know
Check out my CB500T Cafe Racer build diary
clairetoo
posted on 26/6/10 at 08:51 PM |
Probably the same way I found out
I spent all day getting the engine in , plumbed , filled with fluids , then had it up on stands changing the fresh sump..............in the dark
Claire xx
irvined
posted on 26/6/10 at 09:21 PM |
Phew,
This sounds promising, i was worried i'd built a duffer....
Thanks for the quick response guys, i might get out in it whilst the weather is nice after all.
Dave Ashurst
posted on 26/6/10 at 09:22 PM |
Also, even with the right sump, if you dimple the flat shallow part of it enough it will rattle like mad - then you have to push or pull it out.
You didn't support the engine with a trolley jack did you?
posted on 26/6/10 at 09:43 PM |
Been there, done that...
irvined
posted on 29/6/10 at 09:15 AM |
Took the sump off, couldnt see any marks from it being twatted, spent an eternity measuring it against the one that came off, exactly the same size in
the bits that matter.
Lots of head scratching...
Later whilst rotating the engine by hand I noticed that the con rod bolt was grazing the oil pick up pipe ever so slightly. Took the pipe off, bent
it out a little. Job done.
PHEW!!!!!!!!!
