smart51
| posted on 28/6/10 at 08:42 AM |
Is there a locost swaging tool?
I'm planning to make a sheet metal seat for my singles seater. To keep the weight down, I want to punch and swage some 50mm or so holes in the
metal. Swaging tools are quite expensive, as are sheet metal punches. Is there a locost way of doing this?
myke pocock
| posted on 28/6/10 at 08:52 AM |
On my front panels where the wishbones exit I swaged the edge of the holes by first drilling holes with a hole saw. I then cut a similar sized hole in
a bit of thick MDF then chamfered the edge of the hole all around to the profile I wanted. Then place the panel over the hole and gently work around
tapping the alloy into the chamfer. I used a domed wooden hammer but a rubber faced hammer should do equally as good. Time intensive but CHEEP, Locost
and effective.
iank
| posted on 28/6/10 at 08:58 AM |
You can make your own from mdf or steel (if you have the use of a lathe).
Cheapest I've seen for pre-made tooling are here:
http://stores.shop.ebay.co.uk/FAB-PARTS-2009__W0QQ_armrsZ1
Using a bearing under the nut makes things easier.
Using a 50mm hole saw is fine but needs more cleaning up than a punched hole.
Depends how many you want to do really.
Anonymous
jossey
| posted on 28/6/10 at 10:12 AM |
http://www.locostbuilders.co.uk/viewthread.php?tid=138582
smart51
| posted on 28/6/10 at 10:19 AM |
Good for swaging pipes. I'll have a think and see if it can be adapted for swaging holes in sheet metal. I bet something could be done.
MakeEverything
| posted on 28/6/10 at 03:04 PM |
Ive got one made out of steel, and also have two ali seats that i was going to swage. The tool will fir the holes cut in the seats, i just havent
done them yet.
U2U me if you are interested in the seats and the tool.
Kindest Regards,
Richard.
MakeEverything
| posted on 28/6/10 at 03:19 PM |
This is the picture of my seats.
Kindest Regards,
Richard.
