Author: Subject: For Sale ............
Lurch88
posted on 4/7/10 at 06:22 PM Reply With Quote
The Last Of my bits
Front Hubs
Brand New discs when I built my car , Fitted with MK Mushroom Top Inserts
factory reconditioned brake calipers ,new Pads. Brakes have done a few hundred miles only.
£50 SOLD
Front Ball Joints
£10 SOLD
Rear Hubs
Drive Shafts , One Factory Reconditioned
3.6 Open Diff ,Rear Hubs ,new brake shoes and Brake cylinders, Brakes have done a few hundred miles.
£100
Dynojet Kit
Stage one kit for Yamaha R1 1998-1999.
This kit is labelled US Only (Serial No:4165.001) I have been in contact with DynoJet and they assure me that mechanically this is identical to the European kit .
£50
Air Filter
PiperCross Sausage air filter .Back plate cut for 1998-1998 R1 Carbs.
£50
Wind Deflector
Been Drilled and sprayed ,Could probably do with some TLC
£10 SOLD
R1 Clutch
Original R1 Clutch Spring ,Also Have a pack of original friction plates
If they are any good to anyone.
£10
R1 Fan
An R1 Bike Fan mounted in a S/S surround fits to the back of
A Micra radiator.Was efective at keeping my R1 Engine cool.
£20
Centre Mirror
Plastic Mirror mounted on a S/S shaft connected to a Ali base
Made by me to clear the Wind deflector and the centre bar of my MK
Roll Bar
£10 SOLD
Gear Stick and Handbrake Covers
Made by me from Ali fits over the Sierra H/Brake and my gear change.
Drilled and tapped on the back side for grub screws to fix .
£20 SOLD
Pair Rear Flexible Brake Hoses
Came from the back of my MK
£10 SOLD
Tax Disc Holder
Carbon effect Tax Disc Holder
Will have a sixth bolt
£2 SOLD
Pair Of Mirrors
£5 SOLD
S/S Stone Guards
Unfitted
£3 SOLD
pair of switches
£6 The Pair,will through in Hand Brake light
One (Yes ,Only One) Carbon effect HeadLight
£25
Rear Light Set
Compleat with Carbon effect mounting rings
One Stop Tail Light has a slightly damaged lamp mount
£30 SOLD
Number Plate Light Carbon Effect
£4 SOLD
Radiator cap
Looks Like its stamped 15psi
£2
Brake Light Switch
£2 SOLD
Rear Fog Light
Mounted on a machined block on plastic that mounts in vertically on the back
Of a sloping MK rear panel.
£15
In The spirit of resent debate on this forum .
Some of these item are heavy and Pick up would be the
Obvious choice ……….BUT:
I will be delighted to send By , Post /Courier/Pack Mule /
Carrier Pigeon/Camel or any other form of freight you would care to pay for!
Apologies for the extended post but I thought It would be better to get
It out the way in one Hit
If you would like any more photos or other information please ask.
I Live on The Cornwall/Devon Boarder.
[Edited on 5/7/10 by Lurch88]
[Edited on 6/7/10 by Lurch88]
mark chandler
posted on 4/7/10 at 06:29 PM Reply With Quote
Brake light switch, Mirrors, all of them and number plate light for me please.
Cheers Mark
Eternal
posted on 4/7/10 at 06:37 PM Reply With Quote
Sorry probably being stupid but are those sierra front hubs? if so im very interested
Edit humm pretty sure they are. PM sent
[Edited on 4/7/10 by Eternal]
dunk3
posted on 4/7/10 at 07:05 PM Reply With Quote
I will have the tax disc holder please
jossey
posted on 4/7/10 at 07:50 PM Reply With Quote
can i have the rear brake hoses and stone guards and brake light sensor if you still have it.
cheers
postage to leeds would be helpful.
David.
madrallysport
posted on 4/7/10 at 08:56 PM Reply With Quote
Can i have the wind deflector please,
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
Fozzie
posted on 4/7/10 at 09:04 PM Reply With Quote
Lurch...no need to apologise for 'listing in one', that is how 'we' like it to be .....
It keeps it nice and neat for peeps to see, and it helps peeps to see what has gone and what is left, without having to do searches....
Good luck with the sale,
Fozzie
neo2
will you split the gear nob from handbrake lever nob ??
stevegough
posted on 4/7/10 at 09:26 PM Reply With Quote
I will take the rear lights if they are still available, please - U2U sent.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Blackbird Rush
posted on 4/7/10 at 09:53 PM Reply With Quote
Hi i'll take the handbrake lever then if you'll split and neo2 can have the knob.
Ash.
sdh2903
posted on 5/7/10 at 10:23 AM Reply With Quote
You have u2u re the dynojet and filter
