Author: Subject: STACK 8100 display
MydT9
posted on 12/7/10 at 08:30 PM Reply With Quote
STACK 8100 display
Has anyone succesfully used another type of Wheel Speed Sensor or does it have to be STACK;s own branded Wheel Proximity Sensor so that the display can read it? This is the one being advertised for the dash but could I use a more cost effective one
http://www.merlinmotorsport.co.uk/p14541/STACK-PROXIMITY-WHEEL-SPEED-SENSOR/product_info.html
Any help would be useful,
Mydrian
Myd
http://uk.youtube.com/watch?v=RPWhhbaPG4o
hicost
posted on 12/7/10 at 08:54 PM Reply With Quote
Hi
I use the hunter sender on my 8100 last one in the link
James
http://www.merlinmotorsport.co.uk/INSTRUMENTS-/-GAUGES-Speedo-Pickups/c1_272/index.html
"I cant do that without accidentally grabbing hold of the work of the divine potter"
MydT9
posted on 12/7/10 at 09:01 PM Reply With Quote
Thanks but as I'm running a BEC I need a wheel speed sensor as oppose to a sensor to the gearbox. Will keep my fingers crossed.
Mydrian
Myd
SeaBass
posted on 13/7/10 at 09:54 AM Reply With Quote
These are generally just industrial induction proximity sensors that have had a large margin whacked on top.
The trick is to find the spec of the original ie NPN / PNP, supply voltage, sensing distance and then buy from Farnell or eBay. That's what I did for my Speedo when I picked up a suitable sensor for £4 instead of £60.
