Author: Subject: R1
dilley
posted on 13/7/10 at 11:40 PM Reply With Quote
R1
I have just picked up an R1 5VY 01 y-2??
is this a 2004 model??
any feedback on this model engine would be great!! HP etc...
the only problem I have is that the clocks look like they are from a 2001 model according to the ones for sale on ebay, the clocks do plug into the loom (unless they are all the same plug???
pics etc would be great. I have not heard this engine running, are there any potential week weak areas? should I do a compression test??
is this the stronger or weaker engine/box???
Thanks!!!!!!!!!!
A1
posted on 14/7/10 at 12:38 AM Reply With Quote
ive got an 03 one, what do your clocks look like?
Ive heard different, but ive found these engines pretty bulletproof.
get it running, then start playing.
look in my pics, there should be some engine pics there...
dilley
posted on 14/7/10 at 12:50 AM Reply With Quote
Yep!! they are the same clocks although engine looks different, I need to check this engine before it is fitted, it's going in a buggy and needs alot of fabrication.
anyone know how to get around the immobiliser without the master key??
A1
posted on 14/7/10 at 01:29 AM Reply With Quote
you can wire it out. Id have to check, but mine just has a loop on the plug for the immobiliser.
chris mason
posted on 14/7/10 at 07:25 AM Reply With Quote
The engine code relates to a 2004-2006 engine.
The 2004/5 engines had a alloy/silver sump, but the 2006 had a black sump
The clocks may work, but the 2004 engine's max rpm is 13750 and i'm sure the 2001 was approx 2000 less.
As far as i'm aware there is no way round the immobiliser other than using a usa ecu, i believe there is someone out there offering to crack the ecu for around £3-500
The uk loom will work with the usa ecu (can be found on ebay for £100 or less) but you may need to swap a few pins round on the coil and injector plugs.
dilley
posted on 14/7/10 at 07:27 AM Reply With Quote
there is a bypassed ecu on ebay???
£275 I think!
I have the full wiring loom.
[Edited on 14/7/10 by dilley]
dilley
posted on 14/7/10 at 08:21 AM Reply With Quote
Looks like I have a 2006 model!! yey!
A1
posted on 14/7/10 at 08:47 AM Reply With Quote
ill have a wee look at the wiring and see if i can tell you how to wire out the immobiliser
JoaoCaldeira
posted on 14/7/10 at 09:41 AM Reply With Quote
Be aware that 2004-06 need some mods (breather) in order to not destroy themselves!!
Search this list.
dilley
posted on 14/7/10 at 01:34 PM Reply With Quote
I have found an ECU in the USA, problem is my ECU has 2 plugs and the USA one appears to have 1???
