MydT9
| posted on 14/7/10 at 05:15 PM |
Power Commander 3 USB - diy flatshift
I'm sure someone has done this, but i want to use the action of my Kliktronic actuator to signal to the PC3 to kill the power to the coils and
achieve the clutchless flatshift.
I am led to believe that this achievable by connecting the shift signal to the PC3 and adjusting the firmware accordingly. Has anyone done this and
if so, how and is there a wiring diagram I can borrow
The engine is a modded Busa
Mydrian
Myd
http://uk.youtube.com/watch?v=RPWhhbaPG4o
minitici
| posted on 14/7/10 at 06:12 PM |
I think the PowerCommander quick shift function needs to be actuated via software.
The input is just two wires from a switch.
The software comes on a disc from DynoJet.
Not cheap for what is effectively a 'switch' - IIRC about £188 for the switch and software disc.
I fitted one to Angus's Radical - seems to work pretty well.
... and before you ask - no I don't have the software disc!!
franky
| posted on 14/7/10 at 07:11 PM |
think you can download the software for free from dynojet.
paublo999
| posted on 14/7/10 at 07:20 PM |
the software is not available for download and is supplied on a mini cd. One click and the feature is activated.
Looking for it now, but cant find it
[Edited on 14/7/10 by paublo999]
My videos http://www.youtube.com/user/ninjabogeyracing
barbarianbeast
| posted on 14/7/10 at 08:46 PM |
this sounds incredible if its easy as you make out. keep us all posted and im looking now too. im thinking just a switch on the gear stick will do it
too?
barbarianbeast
posted on 14/7/10 at 09:05 PM |
OI!! look what i found!
http://www.gixxer.com/forums/archive/index.php/t-126709.html
http://www.racedevelopments.co.uk/downloads/PCShiftKillEnable.exe
now what switch do you think i can use, and what is the pinout of the port.
paublo999
| posted on 14/7/10 at 09:15 PM |
I think the timing of the cut is important. The units only kills the spark for 60ms which you will not be able to do consistenly if atall from a
manual switch. A microswitch setup a linkage may be possible, obviously easier on a sequential box.
My racelogic box uses a switch on the clutch?
I have a trickshifter with blip but like the idea of diy so will help if I can
barbarianbeast
| posted on 14/7/10 at 09:26 PM |
so what can i buy online that will do the trick. something with an m8 thread either end ideally. rswww has 500 microswitches
MydT9
| posted on 14/7/10 at 09:40 PM |
Many thanks for the replies. I am reliably informed that the kill duration can be fine tuned with the PC3, in fact my old Trickshifter system had a
kill time of 60ms from the factory and that worked fine.
All that's left is to figure out where I run the shifter signal into the PC3 to activate the Kill... as soon as i find out I will post it here.
Got my rolling road in next weeks so will be able to not only fine tune engine performance but also maximise the synchronising of the gear changing
for best results... LCBs save the day again Thanks all
[Edited on 14/7/10 by MydT9]
Myd
barbarianbeast
| posted on 14/7/10 at 09:50 PM |
http://www.cordona.net/shop.htm#gp9
that gp9 switch looks intresting, im currently trauling rsww, maplin etc for much cheaper versions.
paublo999
| posted on 15/7/10 at 07:55 AM |
The pc shift rod is definately plug and play (no splicing) and I believe uses the expansion port.
The install manual has pictures if we can find it
Steve Hignett
| posted on 15/7/10 at 07:59 AM |
I drew this a while ago - does it help?
[img][/img]
minitici
| posted on 15/7/10 at 08:40 AM |
As paublo999 says, the PowerCommander Quick Shifter is a 'plug & play' fit with no wiring splicing required (unlike the Trickshifter
wiring shown above).
The Quick Shifter switch plugs into the PC111 and only has two wires.
Switches are available which fit into the gear rod. These can be push or pull switches depending on which direction your gear rod goes for
upshifts.
They also do linear actuator type switches which mount along side your existing gear mechanism.
Standard factory settings are 65ms cut and only operates above 4000rpm. You can re-program the cut dwell and revs from the PowerCommander software.
The Radical (ZX14) used the standard settings and seems fine.
