jeffw
posted on 29/7/10 at 04:33 PM |
Starter Motor
Long saga with a "please help" request at the end.
I lost my Silvertop Zetec in April (oil filter failure) and since then the car has been with a company while they replace the Silvertop with a new
Blacktop. This has a"CNC Heads" Head and Cams.
I'm waiting to get the car back but the company doing the work has hit a problem. The Silvertop was running a lightened flywheel with a
standard clutch and a CVH starter with the standard bellhousing. The blacktop is running a 81/2" Burton steel flywheel, AP clutch and a
Raceline alloy bellhousing.....
So the desperate cry for help is...What starter motor will fit ? The CVH doesn't engage. a Pinto one the company had kicking about will start
the car but can only be done up on 2 of the 3 bolts as it is too large (in diameter). They have got a smaller Pinto one but that doesn't appear
to work either.
I presume this has been done before so there must be a starter out there that will work.
Thanks....
adrianreeve
posted on 29/7/10 at 04:40 PM |
Having the same problem with my CVH starter not engaging (not enough throw) A bit of research has thrown up the Lucas LRS543 or equivalent as an
alternative.
Hope that's of some use!
Adrian
Lars
posted on 29/7/10 at 06:43 PM |
my starter is only done up with 2 bolts, I cut the 3rd of to clear the chassis member.
jeffw
posted on 30/7/10 at 05:33 AM |
Thanks for the info, I'll get them to buy a LRS543.
