MakeEverything
posted on 30/7/10 at 09:23 PM |
Fenner Vee Belts
Anyone know where to get the Fenner Powertwist Drive belts from?
Im after a 10mm (Ztype) V Belt system, and was wondering about giving this system a go.
http://www.fennerdrives.com/high_performance_composite_vbelts/powertwist_home.aspx?gclid=CJ6ZoKaXlKMCFVFd4wodvD7Kqg
Kindest Regards,
Richard.
Confused but excited.
posted on 30/7/10 at 09:29 PM |
Contact Fenner and ask for nearest distibutor?
They are very helpful.
[Edited on 30/7/10 by Confused but excited.]
Howlor
posted on 30/7/10 at 09:53 PM |
Eriks do them.
Google them.
daviep
posted on 30/7/10 at 10:25 PM |
These have been around for a long time, they don't really compare to a proper v-belt or toothed v-belt in terms of transmitting power and if
they slip at all they wear the pulleys very quickly.
I wouldn't touch them with a barge pole except in an emergency.
Davie
MakeEverything
posted on 30/7/10 at 10:30 PM |
Davie
Or as a prototype to get the correct length and tension......
Kindest Regards,
Richard.
MakeEverything
posted on 30/7/10 at 10:32 PM |
quote: Originally posted by Howlor
Eriks do them.
Google them.
Theres an ERIKS in stevenage. Might be just a repair centre though. Thanks for the tipoff.
Kindest Regards,
Richard.
mcerd1
posted on 30/7/10 at 10:39 PM |
Davie
string should do that
MakeEverything
posted on 30/7/10 at 11:27 PM |
Davie
You cant run string to get the alignment as well though....
Kindest Regards,
Richard.
GMPMotorsport
posted on 31/7/10 at 06:59 AM |
Worth checking if you have a BRAMMER supplier near you, vert helpful for things like that as well as bearings etc.
www.gmpdevelopments.co.uk
www.gmpmotorsport.co.uk
ARDS Instructer.
tonym
posted on 31/7/10 at 08:00 AM |
You have just reminded me I have used these link belts as fan belts on a JCB and another machine as an easy bodge to save removing hydraulic pumps.
They must have been there 10 years with no problems. Normal v belts used to give trouble all the time. Only problem I can see is you cannot run
tensioners or guide pulleys on the back of the belt.
MakeEverything
posted on 31/7/10 at 08:04 AM |
mmm, im not that impressed with the branch manager at my local Brammer. They dont seem interested for single items.
Kindest Regards,
Richard.
MakeEverything
posted on 31/7/10 at 08:05 AM |
Thats ok, because for the supercharger, i dont need a tensioner and the belt will only be between 600 and 700 i think.
Kindest Regards,
Richard.
tonym
posted on 31/7/10 at 04:44 PM |
I dont think I would use them for a supercharger as this will comsume a lot of power. in my opinion the only suitable belt for this application is a
toothed belt.
MakeEverything
posted on 31/7/10 at 07:24 PM |
toothed belt.
Valid point. I think ill heed. Thanks.
Kindest Regards,
Richard.
