Author: Subject: aftermarket ecu
Stuart_B
posted on 29/8/10 at 05:41 PM Reply With Quote
aftermarket ecu
hi all,
well enough new engine now, so just trying to work out the variable value timing on the inlet side.
what ecu can i use to control this?
or/and can some one point me in the direction how the vct work?
cheers
stuart
interestedparty
posted on 29/8/10 at 05:45 PM Reply With Quote
I believe the Emerald can be programmed for variable cam timing, not too too far away from you either.
Pretty good pricewise as well
Stuart_B
posted on 29/8/10 at 06:37 PM Reply With Quote
cheers, will try and have a chat with them soon
stuart
iank
posted on 29/8/10 at 06:45 PM Reply With Quote
Anything with an output that can be programmed to switch at a set RPM should be able to do it.
Anonymous
franky
posted on 29/8/10 at 07:05 PM Reply With Quote
get a used dta one off ebay then you can run traction contorl/launch control/data logging/shift lights etc too.
nz_climber
posted on 29/8/10 at 07:21 PM Reply With Quote
Before anyone can give you a correct answer we need info on engine type etc as it all depends on what sort of variable valve timing you need, and from what manufacture?
for example there is at leats 3 different options just from toyota
VVT (either on or off, based on RPM and engine load)
VVTI ,(continously variable valve timing, controlled by PWM waveform, based on RPM, Load, CAS and Cam angle sensors, knock sensor and probably others too
VVTI-L same as VVTI but with variable lift. Lift is On or Off based on RPM and load too
Most ecu's can control the on off versions (VVT and similar from other manufactures) versions, usually based purely on RPM.
Usually on the more expensive ECU's control the continuously variable stuff and lift, but they are becoming more common these days.
http://aarons7.wordpress.com
Stuart_B
posted on 29/8/10 at 08:06 PM Reply With Quote
hi all, what is dta ecu?
it is a 1.7 ford puma engine which i am doing for a rwd car.
it has vct on it, i do not really want it, but if i have to run it, i need to know my options. as i which to fit different cams in it.
cheers
stuart
Stuart_B
posted on 29/8/10 at 08:36 PM Reply With Quote
like that dta, with launch control, just would like a second hand one through
imp paul
posted on 29/8/10 at 08:52 PM Reply With Quote
have a look here s60 should be the way to go here is a link http://www.dtafast.co.uk/
Madinventions
posted on 29/8/10 at 10:49 PM Reply With Quote
Hi Stuart,
Running my 1.7VCT from the stock Ford ECU... No need for set up or rolling roads.
Ed.
View my band website:
http://www.shadowlight.org.uk
big_wasa
posted on 30/8/10 at 09:46 AM Reply With Quote
Originally posted by Madinventions
Hi Stuart,
Ed.
As above you wont get the same power as the dta. But you will get the drivabilty and save hundreds on an ecu and setup.
Stuart_B
posted on 30/8/10 at 02:39 PM Reply With Quote
hi all, any way i could away from the vct?
cheers
stuart
Criddy
posted on 31/8/10 at 12:26 AM Reply With Quote
Hey, i will be using an OMEX 600 ecu with my 1.7 zetec se VCT engine. i bought this from Shawspeed and will be turning my VCT feature into a V-Tec style feature so on or off at a set rev limit.
Stuart_B
posted on 31/8/10 at 06:29 PM Reply With Quote
hi criddy, cheers for that means i can look at other ecu's
just wondering what setup are you using, regarding the engine to type 9 box?
and fuel system?
cheers
stu
matt_gsxr
posted on 31/8/10 at 10:16 PM Reply With Quote
If you used megasquirt then you could use the shift-light output to drive this.
This allows 4 levels triggered at different RPM levels. You would have to do some electronics as these are low level outputs.
Matt
posted on 31/8/10 at 10:47 PM Reply With Quote
Most aftermarket ECU's will not be able to control full variable cam timing as intended - but it can still be used in an on or off mode.
I an fairly sure the Puma VCT is similar to that used in the ST170 engine, and the timing is fully variable and controlled by the ECU using the phase difference between a cam and crank sensor as feedback.
Stuart_B
posted on 1/9/10 at 06:16 PM Reply With Quote
cheers guys for the advice, and explaining it.
will see what ecu i come up with, i have a mega squirt all ready.
stuart
johnH20
posted on 2/9/10 at 07:51 PM Reply With Quote
Hi Stuart, seems like we need to compare notes when I get back re VCT unit. I am planning to use stock ECU to get my Puma running ( no doubt with help from others on here ) but I have some ITBs waiting and an Omex 600 to operate them. Omex have done some work on the Puma which is why I chose them and they also seem to be the ECU of choice for the few Puma conversion experts out there. See you in a few weeks.
