Arthur T wareing
posted on 5/9/10 at 11:55 AM |
mt75 gearbox
Is it possible to use the mt75 gearbox with a live axel or how easey is it to fit type 9 to twin cam pinto engine as I have both gear boxes. regards
Arthur
snapper
posted on 5/9/10 at 01:25 PM |
You can use either gearbox, the type 9 is smaller and has better ratios.
You will need a prop made up with the correct flanges, no big deal
I eat to survive
I drink to forget
big_wasa
posted on 5/9/10 at 05:04 PM |
Yep I use one with my atlas in the locost.
You need a sliding section in the prop.
RAYLEE29
posted on 5/9/10 at 06:11 PM |
Twin cam pinto are you sure? the only one ford produced was a cossie!
and piper did the warrior
Ray
loggyboy
posted on 5/9/10 at 07:41 PM |
Its an I4 engine in the DOHC sierras is it not? Dont think it was cosworth designed though. The cossie designed ones were based on the Xflow and
fitted to RS1600 and 1800 escorts.
[Edited on 5/9/10 by loggyboy]
RAYLEE29
posted on 6/9/10 at 02:56 PM |
ER yes but an l4 bears no ressemblance to a pinto.
and the cosworth that was based on the pinto is the very famous yb
the cosworth designed crossflow was the fva
the op was obviously talking about an l4 twink but mistakenly thinking it was a pinto.
Ray
