<<  1    2  >>
Author: Subject: How to make MIG welder spool smoothyl
DIY Si
posted on 10/9/10 at 05:55 PM Reply With Quote
Evening all.
Now that I've finally gotten myself a reactive mask, I am now struggling to get my SIP Migmate Turbo 130 to spool out the wire smoothly. This is now getting really annoying as it keeps stopping and starting as the torch moves.
I'm currently running a 5kg 0.8mm reel and the welder is standard.
Is there anything I can do to improve it? Is there a better liner and torch set up that I can get cheaply? Or is it better to try and upgrade to a better MIG altogether?
Sun Tzu, The Art of War
big_wasa
posted on 10/9/10 at 06:05 PM Reply With Quote
You just want a new linear and nip the roller up as much as it will go.
A metal one transformed mine.
iank
Worth having a chat with welduk
They sell this http://www.welduk.com/Details.asp?ProductID=607 so it seems the shoddy feed mechanism is something all SIPs suffer from.
Though £7+p&p is a bit much for a bit of bent steel, something to home fabricate?
[Edited on 10/9/10 by iank]
Anonymous
jacko
posted on 10/9/10 at 06:08 PM Reply With Quote
1 thing to check is that the tip is nipped up tight
Sip ---- "nuff said"
MakeEverything
posted on 10/9/10 at 06:14 PM Reply With Quote
Ditto. Saved mine from the skip with a new liner. I was going to smash it up with a sledge hammer before i fitted it. Now it runs quite well.
Kindest Regards,
Richard.
DIY Si
posted on 10/9/10 at 06:24 PM Reply With Quote
I know, but it was all I could afford at the time. And now I've got it, I'd rather make it work than bin it.
Any links or thing to look for when getting a metal liner for it? I'll have a go at bending the bit of metal up, as I had noticed tonight that the top roller sits wonky compared to the bottom one.
loggyboy
posted on 10/9/10 at 06:48 PM Reply With Quote
Cheap option is to use 0.6 wire. Ive been using it for years and works very well.
l0rd
when i did my welding course, one of my problems was that i was too big to work in the small confined area where we did our practice and the feed pipe was bend enough to annoy me with similar problems.
I ended up puting the feed pipe over my elbow trying to make it a bit more straight and that was prety much it. Spot on welds after that.
Obviously a new tip can make wonders as well as ours were abused from the learners and most of the times, we had to unweld the wire from the tip.
brianthemagical
posted on 10/9/10 at 06:55 PM Reply With Quote
Have a look at the mig forum.
It pretty much boils down to a relay and some caps.
Do you find the wire feed has to be in a sweet spot? The weld is somewhat ripply when it shouldn't be? There is pretty poor burn back/the wire protudes when releasing the trigger?
I was shocked at the difference it made. No need for extra power supplies or anything.
Saying that, i was welding last night and the house lights were diming, which is never going to help.
T66
posted on 10/9/10 at 07:13 PM Reply With Quote
The SIP feed isnt so good, I ran a SIP 150 to restore my Lada (Yes Lada)
It will not be happy with 5kg reels.
It says so on the tin, but stay with the small spools.
A metal liner will help, as the SIP comes a s standard with a pap plastic one. If its nicked inside you will have bother.
I have moved onto a Clarke 195 and much prefer the Clarke to the SIP.
I weld my Lada (Yes Lada) quite often, if your not doing too much with it the the SIP will last ok. Mine did ok after completely replacing floors and sills in the Lada (Yes Lada)
However I wouldnt buy another...
If I can help you any more , ask....
Bigheppy
posted on 10/9/10 at 07:16 PM Reply With Quote
Curtain wire can be used as a liner the plastic coating had to be removed to fit into the torch on my cebora 130. And its cheap.
MakeEverything
posted on 10/9/10 at 07:50 PM Reply With Quote
Top Tip, and Locost too. Thanks.
Kindest Regards,
Richard.
RAYLEE29
posted on 10/9/10 at 08:03 PM Reply With Quote
Hi, also worth checking the wire hasnt gone rusty if you havent used it for a while
Ray
Mark Allanson
posted on 10/9/10 at 08:14 PM Reply With Quote
See here!
http://locostbuilders.co.uk/viewthread.php?tid=142632
MikeR
You may want to look at this as well,
iank
posted on 10/9/10 at 08:18 PM Reply With Quote
*cough* 2nd reply
Anonymous
MakeEverything
posted on 10/9/10 at 09:20 PM Reply With Quote
aaaah, this is a good idea.
Might try this with mine.
Kindest Regards,
Richard.
loggyboy
posted on 10/9/10 at 09:44 PM Reply With Quote
Not always, having too much grip can cause the wire to kink and bundle before going in to the liner if you hit an area with a bad earth.
iank
posted on 10/9/10 at 09:47 PM Reply With Quote
On the SIP the idea is to keep the top wheel running straight.
Anonymous
RazMan
posted on 10/9/10 at 10:40 PM Reply With Quote
My SIP 160 wire feed was very unreliable until I replaced the plastic liner for a steel one and changed to 0.6mm wire. As long as I keep the torch liner as straight as possible with just gentle curves, it's as good as gold now.
Raz
posted on 10/9/10 at 11:08 PM Reply With Quote
You should be able to stop the wire by pinching it between finger and thumb. If it's too tight it crushes the wire and causes a lot of dust in the liner, can also cause bird nesting inside if the wire sticks at the gun.
v8kid
posted on 11/9/10 at 12:17 AM Reply With Quote
I hooked up a laptop power supply to the drive motor electrics 6 months ago in addition to the brace.
Details on various welding sites.
Works well and is cheap
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
Daddylonglegs
posted on 11/9/10 at 07:56 AM Reply With Quote
Glad to see it's a common issue and not just my bad luck. I have temporarily fixed mine with a block of wood jammed up lightly under the lower roller housing, keeps the rollers straight and certainly helps.
But I will be making one of the 'cheap' (not!) strips of steel to make a better, less heath robinson affair
posted on 11/9/10 at 09:15 AM Reply With Quote
errrmmmmmm, without looking, I bet that is larger diameter so it may be more difficult to push trhough the hose.
<<  1    2  >>
