femster87
posted on 13/9/10 at 05:33 PM |
rear brake info needed
just got an hydra mech kit for my rear brake. problem is that rear hub wont fit into the disc.
Is there any solutions such as machining the discs or hub? I need 8mm for clearance which is quite a bit.
or alternatively change the disc. Am just surprised as this were meant to be for sierra (i think).
also my hub is about 146mm dia. is this same for everyone? ( are they all same for all sierra's)
thanks in advance
[Edited on 13/9/10 by femster87]
adithorp
posted on 13/9/10 at 07:08 PM |
You need to have the hub flange machined down to fit. If it's a Rally Design kit I think the info' is on thier web site.
adrian
http://jpsc.org.uk/forum/
femster87
posted on 13/9/10 at 07:36 PM |
hi adrian,
not been able to find anything on rally design page. pointers would be appreciate
phelpsa
posted on 13/9/10 at 07:38 PM |
The hub needs to be turned down to 134mm diameter IIRC.
Yorkie
posted on 13/9/10 at 07:42 PM |
As above the hub is machined to 134mm diameter.
femster87
posted on 13/9/10 at 07:59 PM |
thanks guys
