Arthur T wareing
posted on 20/9/10 at 02:42 PM |
I4 to type 9
Has any one fitted type 9 to I4 engine and is anything required to do so. I prefer the type 9 to mt75. regards Arthur.
blakep82
posted on 20/9/10 at 02:43 PM |
erm, yes. ford fitted type 9 boxes to thousands of straight 4 cylinder engines....
________________________
MakeEverything
posted on 20/9/10 at 02:57 PM |
Suggest you do some reading before asking questions!! There is loooooads of info on what you are after already on here. The search function is on
the top left of the toolbar.
Kindest Regards,
Richard.
mrwibble
posted on 20/9/10 at 03:02 PM |
i think he might mean a duratec, i think that had a code name i4, in which case i reckon the answer is probably yes, with some fettling and a healthy
budget. or perhaps the dohc sierra engine i4, which i think the consensus is not a great option, but is more likely to bolt straight to it as it would
use the ford bolt pattern which didn't change untill the duratec he.
hope helps
fesycresy
posted on 20/9/10 at 03:10 PM |
I4 = crap DOHC that came after the pinto
Now I've also seen the Duratec HE with an I4 suffix, have a look here at wiki:
click me baby......
Have a look under names reference.
If it is a Duratec then you need a bellhousing from Titan / Yukspeed etc because its a Mazda engine.
Have a look for flak monkeys posts, he explains the clutch, fly wheels and more.
spiderman01980
posted on 20/9/10 at 03:38 PM |
I4 is short for inline four, a straight 4 cylinder engine if it had H4 it would be a flat four cylinder like the subaru, V on v6 v8s and 12s and W
like the bugatti and so on! not sure if all engine start with all those codes!
spiderman01980
posted on 20/9/10 at 03:42 PM |
like on fesycresy link it shows the range of engines and the 2.5L st/rs has I5 which has 5 cylinders inline!
mrwibble
posted on 20/9/10 at 03:45 PM |
i'm just going on the info on burton powers website. if you read that wikipedia link though, even the old kents they put in KAs are now
"duratec" though :p
mcerd1
posted on 20/9/10 at 04:03 PM |
"duratec" though :p
I thought that was the 8v 'Zetec RoCam' that was rebadged as a duratec for the KA (its a cheap version of the zetec SE)
its all alloy so hasn't got much in common with kent block
mrwibble
posted on 20/9/10 at 04:05 PM |
"duratec" though :p
i beg to differ
Duratec 8v 60 PS (new renamed old Endura-E) Kent 1.3 L (79.3 CID; 1299 cc) –present OHV I4
ali f27
posted on 20/9/10 at 04:19 PM |
Hi Auther i4 rs 2000 engine bolts straight on duratec needs new bell housing about £200 no probs Ali
zilspeed
posted on 20/9/10 at 04:21 PM |
"duratec" though :p
i beg to differ
Yes, but with an alloy OHC head.
If you were building a 1300cc car and wanted to use a Ford 4 speed, it might actually make sense, but I guess not.
It seems everyone needs a minimum of 150bhp in their half ton car these days to feel that it's even slightly quick.
snapper
posted on 20/9/10 at 04:26 PM |
If it is the old DOHC then either type 9 or MT75 will bolt straight up the new Duratec needs a bell housing, Rally Design do a purpose built one for
around £200
I eat to survive
I drink to forget
mrwibble
posted on 20/9/10 at 04:31 PM |
i beg to differ
getting off topic here, all i was pointing out is that according to wiki ford now refer to all their engines, nevermind their heritage, as duratec,
which is a bit like saying its an engine engine... all which is irrelevant because the method of doing so has succinctly been given above.
RAYLEE29
posted on 20/9/10 at 07:07 PM |
Errm the 2.5 st engine is a 24 valve v6 isnt it? not an inline 5
Ray
hillbillyracer
posted on 20/9/10 at 08:32 PM |
I4 has become the accepted term for the Ford DOHC engine used in the Sierra as well as being a description for the layout of any 4 cylinder in-line
engine.
Google "Ford I4 engine" & you'll find plenty of info on it.
There is of course the possibility that some of you knew that & have deliberately misunderstood the original poster in order to take the mick.
Or am I just being a bit too cynical?
mcerd1
posted on 20/9/10 at 09:02 PM |
Ray
the 2.5 ST engine used to be a 24v V6, but now its a 20v inline 5 turbo (based on a volvo T5 I think)
but they are all called duratec's
RAYLEE29
posted on 21/9/10 at 02:24 PM |
Ooh, so ive learnt something new too.
didnt know that ta
