jollygreengiant
| posted on 3/10/10 at 12:51 PM |
Peugeot Rear trailing arm question for the high & mighty
Ok, what I need to know is does any one know if any of the peuget's have a trailing arm length of approaching 400mm from pivot to centre of stub
axle.
| posted on 3/10/10 at 03:19 PM |
Do you mean on the older 205, 309, 405 models?
Never measured them, but I'd say they're closer to 300mm than 400mm.
Trailer building per chance?
PSpirine
| posted on 3/10/10 at 03:22 PM |
keep in mind a lot of them are shagged, or on the way to it. the bearing design is rubbish so they wear in one spot and you end up with ridiculous
camber!
