New Topic New Reply
Author: Subject: 13'' wheels and brakes!
needforspeed
posted on 11/10/10 at 09:30 PM Reply With Quote
currently running 15s with 285 wilwoods and sierra 2wd rears i can change the fronts/adjust the brackets but what about the rears? will they fit under 13's?
RJK350
posted on 11/10/10 at 09:49 PM Reply With Quote
I'm running 13" Team Dynamics on my MK Indy. Wilwoods on the front and Sierra calipers on the back. The only problem was the hand brake springs rubbing the inside of the wheels. I had some special springs made with 1 coil less to miss the inside of the wheel.
I have sets left as I had to order a minimum quantity from the spring manufacture. Please U2U if you are intrested.
Rob
matt_gsxr
posted on 11/10/10 at 10:10 PM Reply With Quote
No they probably won't fit.
If you have wheels other than Team Dynamics then Sierra disks don't really fit under them.
You can do a hub modification (machine down to 134mm o.d.) and use Mk3 Fiesta front (non-ventilated) disks. These move the disk surface further inboard. Mk3 escort front disks bring it further inboard still, but are a bit heavier.
Not sure whether Sierra Cosworth disks are larger than standard Sierra, but even standard sierra are a problem.
Matt
mark chandler
posted on 11/10/10 at 10:26 PM Reply With Quote
I,ve got proper minilights, had to grind a bit of the rear caliper away to fit, also a set of lookalike minilights, these have much more clearance.
You need to try a wheel before buying... some do, some do not !
Gergely
posted on 12/10/10 at 08:32 AM Reply With Quote
I run 13" Compomotive CXR's on Sierra rear calipers, and have done exactly as Rob, had springs made with one coil less. This now clears the wheel and the stick-on weights.
No problems with the Raceleda front calipers.
Gergely
Our build pictures
hobbsy
posted on 12/10/10 at 08:36 AM Reply With Quote
I don't think TD's are the only ones that can clear Sierra brakes.
I've tried several wheels and once the spring is one coil less they should fit.
This includes CXR's, Caterham 6 spokes, MB mag R500 wheels etc.
matt_gsxr
posted on 12/10/10 at 01:06 PM Reply With Quote
All the cheap ones then.
They don't fit under 4-spoke Compomotive Revolutions, which are the best wheels in the world.
Matt
beaver34
posted on 12/10/10 at 07:05 PM Reply With Quote
what size disks are people running on the rear? i have cossie calipers and i can run 13" wheels
Fredrik Jönsson
posted on 20/3/11 at 09:10 PM Reply With Quote
I have front disks from a Sierra with drums at the rear. Will 13" Team Dynamics fit? What ET should I use?
Fredrik, Sweden
daniel mason
posted on 20/3/11 at 09:31 PM Reply With Quote
i got the modded spring and run 13" r500 wheels. fit perfectly!
speed8
posted on 20/3/11 at 10:20 PM Reply With Quote
Gergely
Me too, CXR's with Sierra rears and Wilwood fronts
New Topic New Reply
