Author: Subject: MT75 to Type9 Swap
Project7
posted on 17/10/10 at 12:50 PM Reply With Quote
MT75 to Type9 Swap
The MT75 i have looks like it might be leaking oil, so I'm thinking of swapping it for a Type9 with a BGH gear kit over the winter.
Is the Type9 a direct swap to replace a MT75, I'm mainly concerned about having to relocate the Engine Mounts, and would like to avoid that if possible. I'll probably be using the Burtons Ali Bell Housing.
I'm trying to get an idea of the knock-on effects would be of the swap, to gauge if its worth doing or not.
smac
posted on 17/10/10 at 01:04 PM Reply With Quote
you'll need a new propshaft
snapper
posted on 17/10/10 at 02:15 PM Reply With Quote
Rally Design for the ally bellhousing, half the price, you may also need an RS2000 release arm and a cct113 release bearing.
Gearbox mount will be in a different position
Prop shaft may need to bo shorter with a different fitting arrangement.
If you use an RS2000 bellhousing you either need an RS2000 ally sump or make up a steel plate to cover the unused starter motor hole which also mounts the clutch cable
I eat to survive
I drink to forget
big_wasa
posted on 17/10/10 at 03:18 PM Reply With Quote
Its a lot of work and money when another mt75 is so cheap.
Is it the ratios your not keen on ?
Project7
posted on 18/10/10 at 08:08 AM Reply With Quote
Thanks for the replies, its given me something to think about.
I think the car would benefit from a close ratio box, and if i get a secondhand MT75 there is no guarantee it will be in any better condition than the one I have. So my thinking was if i am going to have to buy a Recon an MT75 I might as well pay the bit extra for a Type9 and the advantages it brings.
paul@firstmotion
posted on 18/10/10 at 03:50 PM Reply With Quote
Mt75 and Type 9 recon boxes
Hi all
Just been having a quick look at this thread anyone interested in a Type 9 with different ratio set take a look at my site http://www.firstmotion.co.uk/ as we specialise in standard recons and ratio changes for both boxes hope this is of help to some of you
Regards
Paul
