Author: Subject: Diesel remap for VAG 1.6 TDI ???
posted on 31/10/10 at 08:56 PM Reply With Quote
Remaps are well discussed and documented for the VAG 1.9 and 2.0 TDI engines in various states of base tune, but I can't find any info on the web on the newer 1.6 TDI engines.
Anyone had one remapped or heard of anyone who has?
And if you're thinkkg why not just start with a bigger engine - they cost more and are taxed harder
turboben
posted on 1/11/10 at 10:42 AM Reply With Quote
What year and model is it?
auroan
posted on 1/11/10 at 03:21 PM Reply With Quote
The new VAG 1.6TDIs use the newer bosch ecus with enhanced encryption. This basically means no mapping unless you can break the encryption keys.
posted on 2/11/10 at 09:55 PM Reply With Quote
It will be an Octavia next year.
I did wonder whether the remap capability might start to be "discouraged" by manufacturers, particularly where they have emissions regs to comply with.
Ninehigh
posted on 2/11/10 at 10:17 PM Reply With Quote
Thing is why should it be their problem what you do to it? Further to that there's things they can't stop you doing, like fitting a whacking great turbo
posted on 4/11/10 at 09:22 AM Reply With Quote
True, it shouldn't be their concern, but it may be driven by legislation as most things are these days.
You could bolt on a bigger turbo, but you'd then need to remap to take advantage of it.
ChrisW
posted on 4/11/10 at 09:25 AM Reply With Quote
Hi Nick
I spoke to a mate of mine that has a company doing remaps about this. He says that they can't read/write these ECU's yet, but that support has been promised by the manufacturer of the equipment shortly. He's going to let me know as soon as that happens.
It's some fairly expensive kit he's got, certainly not a Mickey Mouse outfit, so I would assume the same applies for most tuning companies.
Chris
