Author: Subject: Lightest plywood
lsdweb
posted on 7/11/10 at 10:09 AM Reply With Quote
Lightest plywood
Hi all
This is car related honestly :-)
I'm looking for the lightest plywood I can get for the dash of my 26R rebuild. - needs to be about 10mm thick. I've got a dash (3 ply) but it's pretty unique so I need to build a new one. The original is light as hell!
I'm sticking to wood as aluminium and c/f just don't look right in a historic car. I haven't decided on a finish yet - possible just black paint or a veneer finish (as per the originals)
Any thoughts
2cv
posted on 7/11/10 at 10:17 AM Reply With Quote
Lotus Elan?
iank
posted on 7/11/10 at 10:24 AM Reply With Quote
If the original is very light at 10mm then it's probably a marine product with a balsa wood core.
Anonymous
interestedparty
posted on 7/11/10 at 10:26 AM Reply With Quote
Light plywood = cheap plywood, usually
Cheap plywood = small number of laminations, very rough cutting
The best way to do this would be to get some decent thin plywood (you will NOT be able to do this at a timber yard/B&Q etc). Model shops are good sources, or anyone who uses birch plywood might have some offcuts. Anyway, thin plywood of say 6mm thick, make up the whole dash, then cut extra layers just for where it needs to be thicker, (cut outs, fixings etc) and glue them on. Then, of course a layer of veneer.
To get the thick, varnish look of older cars you really need polyester lacquer, not DIY stuff, auto restoration suppliers might have an epoxy based alternative.
rf900rush
posted on 7/11/10 at 10:34 AM Reply With Quote
Try the Model plane world.
A product often called Lite Ply is used.
Not sure how large or thickness you can get.
May be worth a look.
liam.mccaffrey
posted on 7/11/10 at 10:35 AM Reply With Quote
Possibly make up your own lamination with veneer and a balsa sheet core? Not sure how structural it needs to be
Build Blog
Build Photo Album
Dave Ashurst
posted on 7/11/10 at 11:01 AM Reply With Quote
Seconded. I think that's what I'd do. I have some smiths gauges on a Triumph dashboard that was clearly made like that.
Alternatively (because I'm lazy) perhaps I'd try making a 10 or 12 mm marine ply blank and router out the back to lighten it, leaving a skeletal frame with a complete face.
Surrey Dave
posted on 7/11/10 at 11:07 AM Reply With Quote
Birch Ply? , used extensively in speaker cabinets.
Neville Jones
posted on 7/11/10 at 11:57 AM Reply With Quote
I did some work a little while ago on a mates yacht, Dehler 36, and was given pieces cut from 10mm 7 ply, that was the lightest ply I've ever encountered. The middle plies were oriented at 60 and 30 degrees.
This ply was made from aircraft grade spruce, I'm told, so the aircraft world is where I'd be looking.
There's a few diy aircraft forums, so you might want to ask on them. I'm sure you'd get an offcut the size you're looking for for not too much money.
Nev.
v8kid
posted on 7/11/10 at 12:10 PM Reply With Quote
I'd go for the sandwich construction I used something similar for my hovercraft and it is unbelievably light, extremely rigid but not as strong as the rigidity leads you to expect.
In your case I suspect it is rigidity rather than strength you need. The rigidity is proportional to the spacing between the skins and the strength proportional to the thickness of the skins.
You really need a press to glue the skins to the lightweight core.
You should be able to get a 10mm (3/8 cos of the USA market) foam core and stick 1mm skins on either side giving a total of 12mm. Rigid enough to walk on but when it goes it goes without warning.
Interesting project!
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
austin man
posted on 7/11/10 at 12:23 PM Reply With Quote
Make it in alluminium and spray with the wrinkle finish paint it will look like an early MG midget dashboard effect. so you will get both lightness and a period effect
Confused but excited.
posted on 7/11/10 at 01:09 PM Reply With Quote
A lot of modellers use Balsa wood coated with superglue. This results in a very light, strong material with a hard surface.
You could try making you dash from Balsa and then painting the finished shape with super glue.
Thinking about it
posted on 7/11/10 at 02:14 PM Reply With Quote
link
Canada EH!
posted on 7/11/10 at 04:03 PM Reply With Quote
Aircraft Spruce and Speciality, USA
jacko
posted on 7/11/10 at 07:18 PM Reply With Quote
Malaysian ply also known as Tiger wee wood
alistairolsen
posted on 8/11/10 at 10:18 AM Reply With Quote
Id be getting some veneer and making my own with a balsa core and epoxy personally.
My Build Thread
stevegough
posted on 8/11/10 at 10:55 AM Reply With Quote
Just a thought - a lot of instruments / switches won't fit into anything that thick....
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
lsdweb
posted on 9/11/10 at 09:32 AM Reply With Quote
Thanks guys.
Plenty to think about!
And I'm still trying to decide whether to mount the fuse boxes, relays and dash loom to the dash or bulkhead.
W
lsdweb
posted on 13/11/10 at 09:29 AM Reply With Quote
Lotus used to route out the back of the dash panels to get the bits to fit.
I found a really light sheet of ply in B&Q of all places. Will give it a try. And it was big enough to make 3 so if I get the first one wrong.....
Wyn
