alawrence
posted on 7/11/10 at 10:11 PM |
zetec BLACK TOP
I now have a new zetec to fit into an MK
I could do with a list of items/things to do..
in terms of engine modsthe engine has a water pump but thats about it...
[Edited on 7/11/10 by alawrence]
austin man
posted on 7/11/10 at 10:21 PM |
silvertop or blacktop zetec as there will be a difference as to what is needed
alawrence
posted on 7/11/10 at 11:15 PM |
Black Top
jeffw
posted on 8/11/10 at 06:23 AM |
Sump (Raceline, Dunnell etc)
Bellhousing (Alloy Raceline or cast iron Ford)
Flywheel & Clutch (Zetec 1.8 or Pinto Racing)
Starter Motor (LRS707 if Zetec Flywheel, LRS743 if Xflow/Pinto Flywheel. Get a decent geared/hi-torque one otherwise the car will have problems
starting when hot)
Alternator Mounting Kit
Alternator (Brise Mitsibushi or Nippon Denso)
Idler Pulley (Raceline + New belts)
Water Rail (Raceline, Retro Ford, Dunnell)
ECU (Omex, Emerald, Megasquirt etc) Remember to budget for mapping time
Intake (Jenveys, Carbs, Bke ITBs)
Exhaust (Decent 4-2-1).
Water Pump (which you already have)
ARP Bolts (Might as well do the crank bolts while it is out and sump is off. Will allow engine to go to 7.5K safely)
Can't think of anything else
alawrence
posted on 8/11/10 at 11:30 AM |
cheers
whats the water rail all about ?
posted on 8/11/10 at 11:36 AM |
Its been done to death, use the search facilty..
Basicaly,
1.8 flywheel
Mk1 Mondoe clutch
Capri cct133 release bearing
Spigot bearing
CVH or DOHC starter
Bike carbs
Megajolt
Reuse one of the serpentine pulleys for the idler
32mm pipe for the water rail
It is LOCOST builders after all...
BCR_AK
posted on 8/11/10 at 05:47 PM |
check out http://www.toyne.org.uk/zetec.html
invaluable resource imo.
includes details of making your own engine mounts, sump chop etc.
some stuff refers to Tigers in particular, but a lot of it is relevant to any zetec installation.
hope it helps!
Anoop Kundi
Building Tiger Avon with 2.0 Blacktop Zetec
