Author: Subject: Handbrake cable joiner?
wylliezx9r
posted on 20/11/10 at 03:23 PM Reply With Quote
Hi everybody,
I'm currently installing my handbrake cable (haynes roadster) I need to shorten the cable, im going to do it at the handbrake end. My question is does anybody know where i can get a cable joiner to rejoin the cable after I've shortened it ? I have used google etc but have had no luck.
Many thanks Dan
George Best
austin man
posted on 20/11/10 at 03:33 PM Reply With Quote
I used the inside of a lerge treminal block clamped it up witht he screws then soldered it to the cable
Dangle_kt
You could use something like this:
http://www.chainreactioncycles.com/Models.aspx?PartnerID=79&ModelID=50883
on them both, and make a small bracket for the two cables to slot into?
Davegtst
posted on 20/11/10 at 04:27 PM Reply With Quote
Speak to an AA patrol. They have temporary clutch cable repair kits which have loads of bits and pieces you can use.
redscamp
posted on 20/11/10 at 04:36 PM Reply With Quote
any good ?
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=0192985
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=4915388
alexg1965
posted on 20/11/10 at 04:52 PM Reply With Quote
I used some of these (type cable clamp into Ebay). I've got some spares that you can have. Just send me a U2U and I'll stick some in an envelope. I'd suggest 2 per join.
PK10 CABLE CLAMP 3MM on eBay (end time 04-Dec-10 10:15:46 GMT)
Alex
posted on 20/11/10 at 06:14 PM Reply With Quote
I used wire cable clamps from B+Q. Cheap and effective though I've heard rumours that some SVA/IVA people don't like them...
RazMan
posted on 20/11/10 at 10:20 PM Reply With Quote
A slightly obvious question here .... Why not just resolder the nipple on the handbrake end of the cable?
Raz
wylliezx9r
posted on 20/11/10 at 11:07 PM Reply With Quote
Because its a disc setup and it dosent use a nipple. It uses a hook type thing that I would never be able to get hold of.
George Best
Tilo
posted on 27/11/10 at 03:25 AM Reply With Quote
Could you post some pictures?
I'm changing my rear brakes from drum to disc but i'm not sure how the handbrake actuates...
2cv
posted on 27/11/10 at 09:14 AM Reply With Quote
All you need to rejoin the cable is to drill out a piece of brass bar to the diameter of the cable insert both pieces of cable in and silver solder. It helps to put a counter sink into the the holes for a nice fillet to form. Job done!
wylliezx9r
posted on 27/11/10 at 12:37 PM Reply With Quote
First picture shows the hook on the rear disc setup. Second picture shows how I connected the cable back together after shortening it. Don't know if the pictures will come out cos I havnt got an effing clue !
Cheers Dan
[Edited on 27/11/10 by wylliezx9r]
George Best
Tilo
posted on 27/11/10 at 12:47 PM Reply With Quote
So what it does is to press the pads on the disc, right?
That won't put pressure on the front pads also?
