Author: Subject: Missed a gear
robertwa
posted on 2/12/10 at 07:51 PM Reply With Quote
Missed a gear
My car is fitted with a 5 speed Yamaha FJR1300. Last Sunday I did a clutchless change from 4th to 5th and somehow messed it up. The gearbox sounded like there was a bag of spanners in there, nothing like a missed shift from 1st to 2nd. I quickly coasted to a stop and gingerly tested all the gears assuming the worst. To my surprise everything is still working.
Should I be concerned? Pull the pan and look for metal bits? What could have happened? It was an almighty clatter........
Thanks!
adithorp
posted on 2/12/10 at 08:14 PM Reply With Quote
False neutral caused by getting your timing out. Done it a couple of times and yes it sounds horendous. Not the best thing for the box but sounds like you go away with it. I've done several thousand trouble free miles since I did it last.
http://jpsc.org.uk/forum/
carpmart
posted on 2/12/10 at 08:41 PM Reply With Quote
Yep, I hate it when it happens!
On 919 blades it seems to be the precursor to gearbox issues, I hope its not on the ZX12!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
robertwa
posted on 2/12/10 at 08:51 PM Reply With Quote
Thanks folks you've made my day!
Fingers crossed.....
gingerprince
posted on 5/12/10 at 12:55 PM Reply With Quote
I've done it a few times. The fun bit is trying to guess what revs the engine should be doing so when you try again to engage gear (without stopping) it doesn't bang quite so aggressively
Yazza54
posted on 6/12/10 at 10:47 AM Reply With Quote
Done that a few times, bit of a clatter then select a gear and carry on. Didn't think anything of it.
I'm unhappy cos I eat and I eat cos I'm unhappy
posted on 6/12/10 at 06:28 PM Reply With Quote
terrible feeling
adithorp
posted on 6/12/10 at 08:27 PM Reply With Quote
Try not to do it too much as sooner or later you'll damage the dogs.
Yazza54
posted on 6/12/10 at 09:29 PM Reply With Quote
Woof.
BobM
posted on 7/12/10 at 07:32 AM Reply With Quote
Always try to remember when you get stuck between gears try to select the next higher gear, so if you get stuck between 3rd and 4th for example try to change up into 4th rather than down into 3rd.
Not very Locost but very BEC
Yazza54
posted on 14/12/10 at 05:20 PM Reply With Quote
If it happens I tend to clutch in and go up a gear. When I first got the car ... trying to be easy on the box I was actually doing the opposite because I was taking too long to shift. It shifts a hell of a lot sweeter the quicker you get off the gas and onto the paddle. Learning curve I guess.
matt_gsxr
posted on 14/12/10 at 11:29 PM Reply With Quote
Interesting, I haven't had this yet.
So what causes this?
Maybe I am trying too hard, or not hard enough?
Matt
phelpsa
posted on 15/12/10 at 01:12 AM Reply With Quote
I've had it once where I put the clutch in and accidentally changed up instead of down (getting used to sequential...). Must have realised what I was doing and just pushed it out of one gear and not completely into the next.
adithorp
posted on 15/12/10 at 04:42 PM Reply With Quote
Matt
No it's just your push rod that bends first.
posted on 15/12/10 at 05:59 PM Reply With Quote
Used to happen to me on my old Z1000.
The noise is the dog on cog not engaged properly and it rattles from side to side.
Yazza54
posted on 15/12/10 at 09:36 PM Reply With Quote
Pretty sure it's my fault not the engine. I've not done it recently, just when I was getting used to the box. Shifts a lot sweeter the quicker I get on the paddle.
