Author: Subject: Car door seals and welding clothes !!
pdm
posted on 6/12/10 at 08:52 AM Reply With Quote
Morning
Car door frozen solid this morning and I think its because we used warm water on it to free it on Friday - any ideas on what I could coat the seals in to get rid of the moisture that won't perish the rubber itself ?
Also I'm booked on a college welding course in Jan - woohoo - I need to bring suitable boots and clothes. I have welding gauntlets which I got cheap from ebay. What else will I need - I haven't got a boiler suit or boots yet.....
many thanks
Paul
cliftyhanger
posted on 6/12/10 at 08:57 AM Reply With Quote
Get some flameproof overalls?? sell on the bay quite cheap. I just weld in jeans and a leather jacket this weather, I find its the grinding that sets firs to things . Avoid polyester stuff next to the skin, sticks when it melts. And I keep thinking about something to stop the little bits of molten metal getting into my boots (no, my trousers aren't to short, but stuff seems to get in there anyway )
cliftyhanger
posted on 6/12/10 at 08:58 AM Reply With Quote
And doorseals...Silicone??
Macbeast
posted on 6/12/10 at 09:21 AM Reply With Quote
Door seals - vaseline. ( Comes in handy for other things )
T66
posted on 6/12/10 at 09:41 AM Reply With Quote
if you use silicone, it has to be the stuff that doesnt set !
vaseline is easier.
posted on 6/12/10 at 09:45 AM Reply With Quote
vaseline is easier.
You need the "Back to Black" silicone spray Simoniz makes. It works on squeaky belts as well.
Vaseline is good on chapped lips
[Edited on 6/12/10 by Peteff]
posted on 6/12/10 at 09:46 AM Reply With Quote
Vaseline's far too messy on door seals (or elsewhere).
Get a can of silicone maintanance spray from Halfords or a motor factors - it does what it says on the tin. A good squirt in the locks helps as well (although remote central locking often negates this these days).
pdm
posted on 6/12/10 at 09:55 AM Reply With Quote
Thanks folks !!
T66
posted on 6/12/10 at 10:03 AM Reply With Quote
Works on my Lada perfectly well....
I have never marked my oily clothes once , nor has the Mrs greased her ball gown.
And the doors dont stick either.
speedyxjs
posted on 6/12/10 at 10:42 AM Reply With Quote
You will need steel toe capped boots for the welding course. They wont let you do it otherwise because of elf n'safety
Daddylonglegs
posted on 6/12/10 at 11:15 AM Reply With Quote
Yep, vaseline. Works a treat. Don't forget to spray your locks AND handles with white grease or similar. If you don't it is possible that the newer cars with these 5p plastic door handles can actually break. The plastic gets so brittle in the really low temperatures that when you pull it too hard because it's frozen it can snap clean off
HTH
dhutch
posted on 6/12/10 at 11:46 AM Reply With Quote
Yeah, silicon spary carnt make it worse. However in the main i think you just need to try and keep them dry and free them with a bit of a shove. Worked for me so far.
Welding cloths, I would just take a set of cotten overalls, doesnt really matter if the flame retardent or not i wouldnt say, but if your buying for the task in hand polyester is not ideal! Then yeah, proberbly a sent of £25 steelies.
That said, when i did a ten week (two hours per week) welding course from school we where sent out in polyester overalls and our school shoes and all came back alive. I did once rest my welding rod (oxy ace) on my lap to find it was the hot end i was resting. After about 30second its suddenly went through my overalls and into my leg, more ove a supprise of it going through the overall than anythign else but it hurt later on and its left a mark to this day. Meh
Daniel
tony-devon
posted on 6/12/10 at 11:52 AM Reply With Quote
good boots, decent gloves, and keep an eye out in the army surplus stores
all my overalls are the nomex ones, warm, practical and flameproof.
not essential, but certainly not going to do any harm by being flameproof.
heavy is good, heavy is reliable, and if it breaks, hit them with it
pdm
posted on 6/12/10 at 05:47 PM Reply With Quote
Thanks again everyone - army surplus stores is a good call, I'll go to the local one I think
cliftyhanger
posted on 6/12/10 at 05:58 PM Reply With Quote
Try fleabay, you get some cheap ex-hire stuff (Under a tenner delivered)
Plus it is sooooo much better to arrive in overalls that are not fresh from the packet
m4maverick
posted on 6/12/10 at 06:18 PM Reply With Quote
Hi, just completed a welding course in Crawley college, certainly recommend it but think it may be dependant upon the tutor.
One thing I would say is, if you are planning welding afterwards get yourself a mask now as the college ones are badly handled and generally trashed. Crawley provided each person with a new set of gloves
I would also consider your own clear goggles for grinding, specifically if pointing tungstens etc as again the college ones were badly scratched and was difficult to see, particularly if your eyes are not great close up.
Remember you can wear glasses under a mask, or get a mask with correction lenses, something worth thinking about when buying a mask.
Mike
